Set Auto Parking Brake for 100% of the time?
wautard1
Eric
Seattle
23 Lightning Lariat
The truck has a parking pawl which locks the rear motor and wheels from spinning. So you don’t need to set the parking brake unless you are on an incline. And even then it’s just to keep the pawl from binding up and make shifting out of park easier.
Most EVs don’t have a pawl and just use the parking brake. Ford added a parking pawl because it’s a proper truck and can do things like tow an 8k pound trailer and park on a hill in San Francisco with the trailer attached.
Sandy’s team covered this in the teardown of the motor.
Whatever a pawl is it isn’t good. This thing rocks so much when parked. Even on a flat surface. Gives a discouraging feeling as my driveway is a hill and has a flat spot at the top.
yes I have to get used to pulling the lever. Just an annoyance since it auto parking brakes on slight slopes anyway.
a pawl is a metal pin or gear that drops into the motor gear to keep it from moving. It’s supposed to have some play in it so it can engage and disengage easily and smoothly. All automatic ICE cars have a pawl in the transmission and do the same slight rocking. The rocking is the wheels rolling forward until the pawl catches the gear.
Like you said, you have to manually engage the parking brake on level surfaces. You can also slowly ease your foot off the brake after putting the truck in park so it rolls slowly while the pawl engages. If you just drop your food off the brake that inertia will cause rocking sensation.
Hank42
NY
2022 Lariat ER
I'd much rather have to manually set the pawl, as opposed the parking brake - flip that logic around! And again, that reaching down to engage/disengage the parking brake? Yeah, I know, F150's design philosophy "emulate an ICE as much as possible" but some things should have been better optimized.
I experienced an odd operation this morning.
Drove the Lightning from home to our favorite breakfast spot this morning, parked on a relatively flat surface, the parking brake didn't set as I expected it shouldn't.
Finished our visited, I unlocked the truck remotely, walked to the truck and just as I opened the drivers door, I heard the parking brakes servo activate, the truck spontaneously set the parking brakes, the dash cluster had a normal pop-up message that it was set.
The truck was not on remote start or departure timer either, when I pressed the start button, the parking brake indicator was illuminated, proceeded to disengage it and all is well for now.
Curious if others have seen this behavior?
Ford Motor Company
Official Ford Account
Ford
F-150
Hey, Noel! I can take a closer look into your auto braking concerns if you'd like. Can you send us a direct message with your VIN and the dealership name/location? To send a DM, just click on our username and select "Start Conversation".
sparta
SF Bay Area
F-150 Lightning Lariat Extended Range
I’ve discovered it only sets automatically for two reasons…
1. Your foot is not on the brake when you shift to park. So if you use 1PD this is easy to accomplish. This sets mine 100% of the times I tested it.
2. The vehicle senses your on a slope when you park.
This is referenced in the manual. See pic.
On a slope is the only one that works for me, accompanied by 500 dashboard notifications.
Would love to have this as a standard feature though.
sparta
SF Bay Area
This is fascinating, thank you for the context! There must be a lot of play in that mechanical stop though, because the truck bounces back and forth very noticably when in park without the parking brake set. I suppose it's more of an annoyance than anything now that I know the pawl is in play and it won't keep rolling away.
Mark Fox
Commerce, MI
1948 F-1, 2019 F-150
Does anyone know how to enable the auto parking brake so it auto sets 100% of the time?
I’m noticing that it will only auto set on a slope. The manual makes no mention of this
Coming from a Ram 1500 which had auto parking brake I figured this truck would have it also.
Anyone have details about how it works?
Does anyone know if you can do this in forscan?
jamelski
Sacramento
2024 Lariat
I have a 2024 lariat and I have finally gotten it to do auto break 100% of the time. Some people are like use one pedal and it would always work doesn’t work 100% of the time it was maybe 7525 It doesn’t for me
The only thing I got to work and works in every drive mo
Truck must still be on, in two pedal mode with auto hold on , ,in drive, open the door auto parking brake will work every time , turn the car off, then the car goes from drive to park . So dumb my wife’s 2021 Mach e will go auto break the moment you turn the car off.😂🙄
I'm being lazy in my search this afternoon, but this has come up before. Plenty of discussion here on what happens today, but it has been put in writing that either with the '24's and future SW updates there would be a change put in place so that either the brake would set every time or you could at least take the option to make it set every time.
Personally I don't like it and am very happy with the way it works today.
Happy to have mine NOT set as well.
WaterboyNorCal
Erik
NorCal
2023 Ford Lightning XLT SR
Nunya business ;)
I don't know - maybe I am just old. But I've driven 50+ different trucks, buses, vans, cars, etc... over the years and when I park my vehicle (any vehicle - manual transmission, automatic, sedan, truck, whatever), because it's an old habit, I do something different. While most people stop the vehicle using the brake pedal, shift into park, and then either take their foot off the brake pedal and then engage the e-brake/parking brake or do so while their foot is on the brake pedal, I learned when I was 18 years old to NOT do this with automatic transmissions - here's why: With many older automatics, especially Ford and Dodge vans and trucks, if you were on any incline/decline and put the vehicle in Park first, and then let the transmission (parking pawl) take the weight of the vehicle, it could be somewhere between difficult and next to impossible to get the vehicle out of Park when you went to drive again, because the parking pawl had taken most of the vehicle's weight/inertia, thereby "locking" the transmission.
The easy solution was to stop the vehicle, and with your foot on the brake pedal, shift into neutral, apply the parking brake/e-brake, and then gently let off the brake pedal until the parking brake took the weight of the vehicle. Only then would we shift the vehicle into Park. Some of the vehicles had nearly or completely inoperative parking brakes, and for those, we would curb the front wheels or chock them with appropriately sized/shaped rocks while in Neutral (obviously need a 2nd person to do this), and then put in Park once the chocks had taken the weight of the truck. To this day, when I am on ANY hill, no matter how gentle a slope, I use this technique. And due to habit, I often do it on flat ground, just because I figure it's better to be sure that there are TWO mechanisms for keeping a vehicle parked - the transmission AND some other option (usually an e-brake, but as explained earlier, other options exist).
