SOC Display in Instrument Cluster?
Lytning
Georgia
lakeguy55
New Hampshire
2023 Lightning Lariat, 2011 F-150, 98 Expedition
Is there an easy way to search the registry? Like Lytning, I believe I'm registered. But with there being no apparent sort order in the list above, it's difficult to be certain.
DIRECT GOOGLE SHEETS LINK
After it loads, select row 6, then create new temporary filter view, with that enabled on row 6.
Ford F-150 Lightning SOC Display in Instrument Cluster? 1700242558084
Now you have header controls to filter and sort upon.
Ford F-150 Lightning SOC Display in Instrument Cluster? 1700242656673
FordTough98198
Domenic
Seattle, WA
22 Lightning Platinum
Business Consultant
It’s my understanding that if your truck is let’s say 10 OTA’s behind, you won’t get them all in one fell swoop. They make different changes to modules and things that then sometimes need a specific amount of time to stabilize or be in place before the next OTA comes. Some OTA I’ve received quickly while others took my truck several weeks and then it happened as normal. I assumed it’s because I don’t drive a lot of miles so if the last OTA needs, let’s say, some miles driven on the truck to trigger the next one then mine will take longer. I’m one or two behind now but they’ve always happened without, so I just don’t worry too much about it. As long as you see the little communication arrows on the screen the truck is sending and receiving data, so when it’s time it should happen.
lakeguy55
New Hampshire
Thanks Taxman. I was sure I had registered but I wasn't in the list. Should be now.
Cool, take note @Administrator or a delegate will review & approve new listings, usually weekly so it may not appear for a few days.
LightningShow
MA
'22 Lariat ER
Product Development
I just noticed I have the SOC on the normal "cluster" view. I exclusively use the Calm Mode on the dash because I want to see the SOC. I hadn't checked the normal cluster view for a while. I was happy to see they finally added it.
Review Fordpass, Account > Message Center for an old alert
Priority Update: 22-PU0930-RBA-CHM
That be when you got the update.
LightningShow
MA
'22 Lariat ER
Product Development
Looks like I got it July 25th (y)
Daragh
North Carolina
2023 Lightning Lariat ER
Reading through the thread haven't seen what software version brings the SOC remaining percentage to the cluster.
I'm currently on 6.8.0, no updates for the past 3-4 weeks so not sure what or if I'll get another anytime soon. Was wondering if anybody knows what software version brings the update that shows the SOC in the cluster.
That's interesting, recently a few folks had seen the SOC digits after receiving 6.8.0, maybe this has been split out of the latest version????
rugedraw
Javier
Miami
Auto Sales
Are you confident that 6.8.0 installed successfully?
rugedraw
Javier
Miami
Auto Sales
As far as I know, display said it correctly installed but I am unaware of a way to verify??
Post or send me the VIN.
Got your message. You have not been sent IPC OTA 6.8.0 yet. Once you do, you'll have what you're looking for.
Daragh
North Carolina
Thanks for verifying and the update, much appreciated.
