COrocket
F-150
I can definitely see Teslas concern here - on my Model 3 charging at a 150kw station the handle gets extremely hot after more than 10 minutes of charging. I can see why it was mandatory for the 250kw stalls to have liquid cooled cables which actually seem to stay a bit cooler.
I couldn’t imagine how hot an uncooled extension cord would get at a 250kw station hooked up to a 250kw vehicle. Unless the extension has some way of regulating power or is the thickness of a fire hose
Tony Burgh
Tony
Western Pennsylvania
22 Lariat ER
Heat = I^2*R if I remember correctly (ChemE, not a sparky)
If the conductor is too small and excessive heat generated, it must be removed. Hence water cooling.
If conductor is adequately sized to carry current at lower resistance, less (or little) heat will be generated and little need for auxiliary cooling.
Maybe the extension cord has correct gauge copper. Maybe Tesla went cheap on copper. I hope not aluminum (ductility).
BeeKind
Long Island, NY
'23 F150 Lightning, '23 Ioniq 5
Water cooled aluminum alloy, ever wonder why they're so thick?
Copper has the problem of walking away in the night.
RickKeen
Minnesota
F150L SR Pro
sw engineering manager,
The correct gauge copper can handle the current. Its just expensive.
Nobody going to buy a $1000 extension cord.
husky10101
E Wa
Their extension chord is 16 feet, you don't need a 16 foot chord to adapt to a Tesla supercharger. Only a few feet will do.
Extension cords create heat, losses and multiple points of failure.
Literally any extension cord.
This is not rocket appliance.
