WillB17
Will
2021 F-150 Lariat Powerboost
This is badass looking! However, I cannot get past the login. I put in my credentials (even confirmed them several times through my attempts) and still get an error that says "The data couldn't be read because it isn't in the correct format" Any tips on what I'm doing wrong? I'm very tech savvy so I'm scratching my head at what's going on...attached is my log
Am I the only one having this issue? Getting the same results on both iPad and iPhone. Would love some insight.
tonesto7
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
That’s a new one. These are the issues that are hard to debug with out seeing it first hand.
WillB17
Will
Let me know how I can help. I can always take a screen recording and send it your way. Also I see you’re in Michigan also. It seems that when the script gets my data from the ford servers it’s not able to interpret it, at least that’s what I’m getting from the logs. And I noticed it didn’t matter if my password was correct either, or if my vin was even valid.
tonesto7
tonesto7
Anthony
At the top of the script code, what does it show for WIDGET_VERSION?
tkbolts21
Tim
2016 F-150
This is awesome! Thanks!
Dont want to hijack the thread but I could never find a way to do this - does anyone know a way to create a shortcut or script for turning on and off the "explicit content" on iphone?
tonesto7
tonesto7
Anthony
I don't think that is a feature that apple exposed to shortcuts
tonesto7
tonesto7
Anthony
New Release v1.1.1:
  • Initial support of Electric Vehicles (battery charge, and range)
  • Added screen size detection to adjust the font size on iPhones with smaller displays. (Will be used later to fine-tune the padding of the widget).
  • Added a version check to show you on the widget and main menu if there is a new version available.
  • Low Voltage Battery Text now shows up as a red when it is low.
  • Status Text is displayed at the bottom of the widget. When a vehicle is in deep sleep mode, the firmware update is in progress, or the vehicle is in a low voltage battery state, the status text will be displayed.
  • Fixed bug in using metric and defining psi tire pressure.
  • Tweak the padding of the widget to make it more consistent.
  • Fixed tire pressure font so it matches the rest of the widget.
Script Link: https://raw.githubusercontent.com/tonesto7/fordpass-scriptable/main/Fordpass Widget.js
RedTXV
2021 SQ Limited
New Release v1.1.1:
Are the changes suggested in post #57 still needed with this newest script?
Plattypuss
PA
2021 F150 Platinum PowerBoost Rapid red
Sadly still getting the same error :( Ugh. Was hoping I would get lucky with the latest patch
I'm getting the same error. I'm not as tech savvy as either of you but I'm not a tech idiot either.
Bbass5
Birmingham
F 150
Question: How secure is my login info? Does it get saved in scriptable or emailed to you or something?
tonesto7
tonesto7
Anthony
It's stored securely in the iOS keychain. I can't see anything!
Please review the script code so you can see everything it's doing if you are more comfortable :)
It's basically emulating a Fordpass app to get the data.
