iceman77
Pete
2022 Ford F-150 Platinum
I'm a stubborn SOB, so I paid another $50 to get my FDRS license re-upped and found this waiting on me. Could this be why it's not kicking off the usb update for APIM? And if so what can I do?
Click on Toolbox, select APIM (its under HS3 section) and run Self-Test. See what's the issue and try to clear the fault.
Ford F-150 Lightning ECU module programming guide using FDRS 1642543987407
Post a screenshot if you need further assistance
iceman77
Pete
NOTICE: Should you run into issues where your SecuriAlert and/or OTA updates disappear from your FordPass after messing around with FDRS, chances are, your As-Built data got corrupted during one of your network scans. You can easily fix this by re-running a network scan within the FDRS. For more info read this thread.
TJSparky
WA
2021 F150 XLT (302A) RockyRidge K2
Hey SpeedRacer, I’m still no joy with mine kicking off from 1.7.1 either. So frustrating.
libby2cm
Ashland, VA, USA
2018 F-150.. 2021 on order
IT Manager
Is no one pissed as i am that on this 'fully OTA updatable' truck, UNDER WARRANTY, we have to purchase FDRS licenses to update fords crap code?! It always chaffed my ass with older vehicles, but surely this one won't need it! NOPE! What a joke.
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
You have posted variations on this theme on several threads. Do you have anything other than whining to contribute?
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
Argh that sucks! All my modules are up to date, whatever DTC I had cleared itself but no matter what wonky way I've tried no joy on getting it to kick over. Ford really screwed the pooch on 1.7.1 update it seems.
iceman77
Pete
Did you try Sync Master Reset ? Perhaps reset the GWM prior to that (using ForScan) ?
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
According to his profile, he doesn't have a 2021 truck yet, although he might and hasn't updated yet, kinda like Ford? :)
I'd be willing to PayPal him for his 48 hour FRDS license if it would FIX his broken truck and bring him good cheer!
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
I've Sync Master Reset at least 10 times now, I'm starting to worry I'm gonna reset it to death. I had not tried to reset the GWM though, I'll give it a go now.
TJSparky
WA
How do you reset the GWM in forscan?
iceman77
Pete
Disregard… I found it, the wrench icon in forscan.
I would do something like this. Remove USB, reset GWM, insert USB. See if it kicks in
If not, then perhaps, remove USB, reset GWM, reset APIM then insert USB. Hope you get it done!
JEB
Northern Illinois
Iceman. I don’t remember where you posted about bad behavior with the adaptive cruise control, but something weird happened on my 4-hour drive this morning. When I tested my setup after your first post, I configured the cruise control to recognize speed signs. Like your system, mine also didn’t keep the setting past one ignition cycle. But I never actually used the cruise control or set it back to default. Multiple days and ignition cycles later, when I used cruise control for the first time this morning after updating my APIM, it worked exactly like it was supposed to. The adaptive cruise control changed the speed setting according to the changing speed limit signs. When I went into the settings, however, it still looked like cruise control was off. Not just the “smart” part but the entire function. So, at least on my system, it did work as I configured it a few days ago. The display just didn’t show the settings accurately past one ignition cycle.
I’m not sure if this is a better or worse result. But there it is.
