ROBB1
Justin
NC
2021 F150 Tremor
Gave this a try today and still no go... I already had auto increase on and my min delay was actually already running at 1 ms without changing anything, actually went up to 2 ms when I changed the COM port settings.
So no idea what the deal is really, think the next thing is to send logs to Forscan and see what they think. I wonder if it's just a Job1 build/software issue. My VCXnano should be here shortly so maybe once I try to update everything I can things will start clicking.
I think the best bet may be sending a log to forscan. It seems there are a lot of mixed results with writing the the HVAC module. Forscans data base may not be totally complete. I got lucky I guess.
johnatuckeriii
Houston
2021 F-150 FX4 SuperCrew AMB
Job1 501A, heated and cooled seats but no heated steering wheel
I have a 500A Job 1 2021 with the same. I still can't help but think this is a pattern. If someone sends logs to Forscan it would be awesome but I suspect this is the issue.
ckosmas
2021 F150 Lariat Crew 5.0
I've started adding FORScan spreadsheets here for anyone interested: https://bit.ly/3cJnYMS
Currently the newest version of FORScan can only change the BCM and 1/3 of the IPC (cluster) versions so when that changes I'll add the other modules as well.
My FORScan tutorial is here: https://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY/edit
Enable cameras at speed not working on my '21 F150 Lariat. The changes in your spreadsheet only allow the camera button the dash to make a popup on the main screen "warning, cameras are disabled for your safety". Where as the camera button does nothing without the code, either way, no cameras. Any ideas?
Platinum Peasant
West Sacramento
Did you have the dealer perform an IPMA update as stated earlier?
Ajzride
Alan
Houston
Eng
check your IPMA version then triple check your changes? I have a job 1 lariat 502a and it worked for me.
edit: I see you said spreadsheet. I changed the registers listed below from the post, perhaps the spreadsheet has a typo, I can’t sort it very well from my phone.
Originally Posted by Livnitup
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? viewpost
Here are the final (for now) changes to enable cameras in motion and this has been added to the Common spreadsheet:
IPMA 706-02-02 xxxB CExx xx--
APIM 7D0-01-01 xxxx xxxx Fx--
APIM 7D0-01-04 xxxx EDxx xx--
https://www.f150forum.com/f129/forscan-14th-gen-f150s-481816/index152/#post7124189
Shotofpadron
Rob
ND
2021 F150
Have any powerboost owners had issues turning the pedestrian alert off? I had a 4 check digit and switched it to a 0 but may try the other method in the link too
Ruffiano99
Joe
NY
2021 f150
Dont forget to unplug the module otherwise you will still hear it.
Lodans
Austin, Texas
2021 F150 Powerboost King Ranch
Building Automation
Mine worked great. I used the suggested checksum in the instructions.
BLoflin
Brooks
Austin, TX
2022 KR PB 6.5'
Is there a way to disable the front parking aid sensors/warnings, in the situation where you have a winch (or bull bar) installed (blocking the sensor) so that you do NOT get the warning EVERY time you start moving?
RapidRedRick
Rick
Northern Virginia
Ford F150 Platinum Powerboost
Quick question: in block 3, xx--. What are the values for the dashes ?
Ajzride
Alan
Houston
Eng
Checksum, Forscan will calculate them for you.
imnuts
Dirty Jerz
'21 502A Powerboost 4Ă—4
Facilities Engineer
Is there a way to disable the navigation popups in the instrument cluster? To me, they're more annoying than helpful. I looked through the settings in my truck and didn't see anything, but I'm not sure if ForScan can help or not.
