johnatuckeriii
@superfordman what level lariat do you have? does it have a heated steering wheel?
I think the best bet may be sending a log to forscan. It seems there are a lot of mixed results with writing the the HVAC module. Forscans data base may not be totally complete. I got lucky I guess.Gave this a try today and still no go... I already had auto increase on and my min delay was actually already running at 1 ms without changing anything, actually went up to 2 ms when I changed the COM port settings.
So no idea what the deal is really, think the next thing is to send logs to Forscan and see what they think. I wonder if it's just a Job1 build/software issue. My VCXnano should be here shortly so maybe once I try to update everything I can things will start clicking.
Job1 501A, heated and cooled seats but no heated steering wheel@superfordman what level lariat do you have? does it have a heated steering wheel?
I have a 500A Job 1 2021 with the same. I still can't help but think this is a pattern. If someone sends logs to Forscan it would be awesome but I suspect this is the issue.Job1 501A, heated and cooled seats but no heated steering wheel
https://www.amazon.com/gp/product/B...io-20&linkId=54a831d2c68c75bf681bb5eb68503c3fIs there not a new version of Forscan where you can read each item and enable/disable/change each by line item instead of going in and changing numbers?
I've started adding FORScan spreadsheets here for anyone interested: https://bit.ly/3cJnYMS
Currently the newest version of FORScan can only change the BCM and 1/3 of the IPC (cluster) versions so when that changes I'll add the other modules as well.
My FORScan tutorial is here: https://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY/edit
Did you have the dealer perform an IPMA update as stated earlier?Enable cameras at speed not working on my '21 F150 Lariat. The changes in your spreadsheet only allow the camera button the dash to make a popup on the main screen "warning, cameras are disabled for your safety". Where as the camera button does nothing without the code, either way, no cameras. Any ideas?
check your IPMA version then triple check your changes? I have a job 1 lariat 502a and it worked for me.Enable cameras at speed not working on my '21 F150 Lariat. The changes in your spreadsheet only allow the camera button the dash to make a popup on the main screen "warning, cameras are disabled for your safety". Where as the camera button does nothing without the code, either way, no cameras. Any ideas?
Dont forget to unplug the module otherwise you will still hear it.Have any powerboost owners had issues turning the pedestrian alert off? I had a 4 check digit and switched it to a 0 but may try the other method in the link too
Mine worked great. I used the suggested checksum in the instructions.Have any powerboost owners had issues turning the pedestrian alert off? I had a 4 check digit and switched it to a 0 but may try the other method in the link too
Quick question: in block 3, xx--. What are the values for the dashes ?check your IPMA version then triple check your changes? I have a job 1 lariat 502a and it worked for me.
edit: I see you said spreadsheet. I changed the registers listed below from the post, perhaps the spreadsheet has a typo, I can’t sort it very well from my phone.
Originally Posted by Livnitup![]()
Here are the final (for now) changes to enable cameras in motion and this has been added to the Common spreadsheet:
IPMA 706-02-02 xxxB CExx xx--
APIM 7D0-01-01 xxxx xxxx Fx--
APIM 7D0-01-04 xxxx EDxx xx--
https://www.f150forum.com/f129/forscan-14th-gen-f150s-481816/index152/#post7124189
