Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
I thought all the 'cheap' adapters only emulate J2534-2 by fragmenting packets or frames a certain way. It may be part of the problem. The ForScan developer wrote a lengthy post explaining this sometime ago. Unless someone buys a high quality full-chipped VCM 2 clone like an SP177-C (which are no longer made) or has an actual VCM 2 or VCM 3 at their disposal the experience is likely going to be more cumbersome when using low-end devices.
Livnitup mentioned he used his VCM 2 clone for FRDS updates and has not had any issues. I don't know what revision he's using. It's harder to find a good one because there's clones of clones all over the market... and lots of trash too.
That is old news, @JEB and I tested the Mongoose out extensively and the only corruption came from my end and was due to install issues which after running the tests in the J2534 Toolbox that came with the Mongoose did I get it fixed. The Mongoose is a far faster device then the Nano (and I have tested it) and no corruption at all! The Mongoose is the best option without having to spend over $1,000.
nicholsbradley
Bradley
Louisiana
2021 Ford F150 Platinum
Analyst
Can someone check that the updates are available to me before I go down the rabbit hole? 1FTFW1E89MFA46118
Refactoringdr
Don
Albion, IL
F-150 2023 Lightning Platinum (ER)
I hate to "me, too", but I would like to know if there are updates for myself. If there are updates, I can talk to my dealer (he's pretty friendly). Thanks! VIN: 1FTFW1ED0MFA88769
nicholsbradley
Bradley
Louisiana
Analyst
Yea I just called and the reason I was asking the guys for help. 3 different ones in Texas said they will not do them. I had to wait for OTA
Bob_Mac
Bob
North Carolina
restart loop
Same as me on the GWM update. Fail the update but, remove the USB stick from the USB on the truck and go the CANBUS route.. if the stick is in you won't get that option.
Bob_Mac
Bob
North Carolina
Just chiming in that GWM & APIM update went smooth using VCM2.
I had success with the GWM but doing it via CANBUS, APIM now in progress so let's see how that goes. Too bad the VCM2 is no longer available...
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
You might get a pillow and blankey, because you will be spending the night in the captains chair of your mighty Powerboost. (there's a scroll bar, if you know what I mean ?)
Ford F-150 Lightning ECU module programming guide using FDRS REFACTORINGDR.PNG
