ColoradoHunter
Dennis
Colorado
2021 KR, 4X4, AMB, FX4
Just an update. 36 hours post FDRS updates and Hybrid function has returned to normal. Not sure why the "cold" thing showed up. But hasn't been a factor all day. So maybe warm plus x number of engine on/off cycles and it clears up?
And a side note. Been 374 days since I picked up my truck. And for the first time EVERYTHING WORKS as Ford said it eventually would. Thanks all. Really took a "neighborhood" to get it done.
I'm one of the ones stuck in the OTA purgatory. My truck did the same thing, one time, a few weeks ago. No electric for over 20 miles and engine cold for the reason, temp gauge was showing normal operating temp. I stopped for 30 minutes then all was normal. I've just chalked it up to a one time computer booting glitch.
MikeYQM
Moncton NB Canada
2021 F-150 Platinum Powerboost | 2013 BMW M3 Comp
So the GWM took. This is the list of modules updated in the last few days in order. I can’t be sure that the IPMA actually took with block 4 or not, but the USB validation certainly wasn’t done. I have no further updates in FDRS. IPC is still in progress though. ABS showed an update on Monday but it’s gone and was never updated.
is there a way to verify what my IPMA software is/should be showing?
  • CCM
  • PSCM
  • CMR
  • IPMA???
  • GSM
  • TRM
  • DDM
  • PDM
  • GWM
  • IPC
FordConvert
Craig
Utah
2021 F-150 Lariat PB 502A
Builder
Took the truck in for TSB 22-2117 this morning. Service advisor just called saying "yeah there some issues with OTA communication but we can't figure it out and are waiting on Ford"
FDRS here I come.
jordandev
Jordan
2021 F150 XLT 302A (on order...)
Having another issue now.... so here is what I did from the beginning:
started at stuck 1.7.1, revision 144
1 - GWM - usb. success, horn/lights showed up in fordpass
2 - APIM - usb. success - sync revision went from 144 to 244. can schedule updates multiple days now
3 - TCU - usb. success, then fdrs stuck on final config step, but then fine
4 - GWM - failed right away (before usb etc). then the update disappeared... ? but all green, no DTCs, and everything else looking good, so continuing...
5 - DDM - no usb. success
6 - PDM - no usb. success
Now all I have is these 4 left and Download gives an error (also no modules listed as fully updated in the bottom right anymore?):
Ford F-150 Lightning ECU module programming guide using FDRS 1648243726897
All my modules are green. My wifi is fine. Is FDRS down? Is something else broken on my end? Have restarted FDRS etc...
JasonATL
Jason
Atlanta
2021 F-150 Platinum
I’m getting the error trying to download as well. Seems the ford servers are down or having an issue. ☹
MikeYQM
Moncton NB Canada
I just got a login loop. Restarted FDRs and seemed to work. Downloading ok it seems
MikeYQM
Moncton NB Canada
I just installed the APIM for 22028 358 and the GWM is installing now. At which update should I see BC stuff?
I know there are more after this GWM that will pop up, but seeing BC stuff show up will be a good status confirmation.
Jesse-Infotainment
2021 F150
APim - 21281, Gateway, APim -22034
jordandev
Jordan
Yes downloads are back now thanks. GWM update is back now too.
But I get an error,
ignition on step it communicates fine, ignition off it gives a comm error
Ford F-150 Lightning ECU module programming guide using FDRS 1648246043725
happens with either a GWM update or a config. have tried a dozen times. I'm still connected fine otherwise.
Jesse-Infotainment
2021 F150
Leave ignition on.
jordandev
Jordan
Leave ignition on.
Thanks. Yep tried just leaving it on when it tells me off but same problem comm error
GWM update has dissapeared again so can't try again now. Something odd going on.
Jesse-Infotainment
2021 F150
Sounds like it. I was doing something and was having the issue with downloading. Send me you vin and let me see if I can see the gateway update
MikeYQM
Moncton NB Canada
I’m all out of updates. Currently at APIM 22034 354 and all modules green.
I did get a ford pass blue cruise active notification.
My Sync screen does not show any blue cruise information.
my driver assistance settings don’t show anything to enable blue cruise.
Any ideas?
ksimon123451
Kelly
21 F150 Lariat
Systems Administrator
But I get an error,
I was having the same issue, I waited till the next day and it started working. I think your truck needs to report to the mother ship that it is good to go.
