jordandev
I think the IPMA as well as it will kick off a CCM? I ran a network scan with the Nano a few times but was careful to check for corruption every time and close fdrs + rescan if found ??‍You are not risking anyrhing with Nano as long as you stay away from FDRS Network Scan and/or CCM module update. If you need to create USB update flash drive for modules such as APIM, TCU or GWM, Nano will work just as good as the Mongoose interface
About the earlier cancelling talk I’m wondering about something… I did have to cancel once while the button was greyed out. TCU failed on the last configure step. Then multiple times, then it hung on the configure step for an hour+ and I cancelled out (fdrs warns about snorting when doing so) No issue now with the TCU that I can see…. but retrying a configure seems to still fail (didn’t try a PMI or anything). But the module is green so I hope nothing went wrong there. But stuck at 21281 from something…
