biers
- First Name
- Thomas
- May 21, 2021
- SW Washington
- eGolf
Well crap, looks like I'm ordering another part. At least I can use most of what I put in. Thanks for the heads up.As covered in many other threads on this site and elsewhere (YouTube), an interlock won't work with pro power. You need a generator transfer switch/critical loads panel.
I think the consideration for the HIS is system is the following:
1. Do you have long enough outages, or dependency on power that you need backup. For me, being on well is the tipping point, as no power AND no water sucks!
2. Is the truck battery enough, or do you need solar to charge the battery during the day (if in fact HIS does this, we still don't know for sure).
3. Do you have a use case otherwise, say a off grid cabin that you can power with solar, and when you are there, with the truck.
