FlasherZ
- Mar 10, 2022
- St. Louis Metro
- F-150 Lightning, Tesla Model X, F250 SD diesel 6.0
For what it's worth, Tesla had this exact same recall in Model S in 2012 or early 2013. Default programming on their Continental TPMS systems were set too low. The particular subsystem they used couldn't be upgraded by OTA, either, and they had to reset the units using a special tool.To be clear, this isn't a problem with the TPMS sensor modules themselves.
The way I'm reading it, the software thinks the correct inflation pressure is 35 PSI when it's actually supposed to be 42 PSI. If that's the case, the software wouldn't alert you of a low reading between 35 and 42 PSI but would issue an alert if it's below 35 PSI.
@Mike G discovered this discrepancy almost 3 weeks ago.
Maybe the engineers at @Ford Motor Company should monitor this forum to avoid future embarrassment.
