tx_lightning
What is the N Clock button for?? I don't see anything changes on the dash when i press it.
Temporary Neutral activationWhat is the N Clock button for?? I don't see anything changes on the dash when i press it.
The manual does a good job of explaining its use. But to further explain: your car will go back into park when the door is opened, even if you have the shifter in N. The button allows you to put the car in N and exit the vehicle.What is the N Clock button for?? I don't see anything changes on the dash when i press it.
From the Owners Manual……..
thanks! I did search the manual, but I had no clue what I was looking for!Temporary Neutral activation
Most likely similar to a automatic transmission, a solenoid actuated pawl prevents the reduction gear from turningOn a related thought, what does putting the Lightning in "Park" actually do? I am assuming something physically engages somewhere in the drive line to prevent the wheels from rotating but does anyone know exactly what happens?
Thanks
jta
But twice!Put it in Neutral, then press the button.
Agree…….thanks! I did search the manual, but I had no clue what I was looking for!
so this only needed when exiting the car and you want it to stay in neutral up to 30minutes? I can’t ever see needing this in my life
If you break down and need to get pulled on to a flat bed, you will need this.thanks! I did search the manual, but I had no clue what I was looking for!
At a car wash is when you will use it, unless you go to one of those touchless washes that moves around your vehicle.thanks! I did search the manual, but I had no clue what I was looking for!
