VTbuckeye
Reducing the charge rate to 64 amps should not make a huge difference in total charge time 90 percent charge 117kwh will be about 8 hours versus about 6 hours (ignoring charging losses). And it will be even closer if the 80 amp charging gets paused periodically due to excessive heat. If the evse can not sustain 80amp then it should not be sold/marketed as an 80amp EVSE. If they said that it is a 64amp evse, fine, but saying that it is 80amp, when it can not consistently deliver in real world settings is false advertising.
