Thoughts on the Charge Station Pro...
Gimme_my_MME
Is anyone beyond Ford social media damage control department reading these boards?
Oh yes, these forums get read by all different levels at Ford.
Would be nice to hear from a Ford engineer now and then! This forum is your early adopters and their experience will have big effect on future reputation. “One happy customer… “
That's where things get murky. Many would love to reach out and talk directly to customers as there is no better way to get feedback and make improvements. But communications between OEM and customers are actually regulated under the TREAD act.
I can assure you with 100% certainty that there are Ford people lurking around here taking in the feedback though
PiMatrix
Phil
New York
F-150 Lightning
Electrical Engineer
Interesting,
I just read a bit about the TREAD act -
https://en.wikipedia.org/wiki/Trans...ncement,_Accountability_and_Documentation_Act
that resulted in TPMS tire sensors and need to report to NHTSA early defects. I'm not sure how that would affect feedback from assigned employees to forums. For example Enphase solar has excellent board where Enphase moderators provide answers to questions, not perfect but very useful. However in that case Enphase owns the board and does control who is allowed to post. However, I'm sure the TREAD act doesn't stifle good discussion with technical reps. In fact they may prevent the very issues TREAD is meant to address.
It's good to hear that the design/quality people are taking notes because I think this forums early adopter is priceless in keeping future costs to a minimum vs fixing years later, not to mention customer satisfaction. The earlier an issue is caught in manufacturing, design, etc, it is orders of magnitude cheaper to fix. 100K cost now is $1.5 Billion years from now. A whole department should be created that does nothing but prioritize and create tickets from nuggets in these posts (e.g. frunk hood, charger, etc). I do remember reading about Ford hiring a guy that was going to work exclusively on recall/quality issues early in process. What an amazing ROI that will create. 1.5B jury ruling thing this week on F150 rollover (old models) is a disaster outcome that surely could have been acted on quicker with such a priority.
Nick503955
Nick
San Diego, CA
2023 Ford Lightning Lariat, 2024 Kia EV9
I'm unable to reset my Ford Charge Station Pro (FCSP). When I press and hold the factory reset button in the top left, nothing changes, even after 20-30+ seconds.
I've power cycled the device a few times but I can't get access to the local access point and it no longer connects to my home network.
Has anyone dealt with this?
Kentrider
2022 F-150 Lightning Lariat
Whoa! This is all very illuminating and discouraging. I just purchased and took delivery of my FCSP at the dealership. I don't have a garage and have been researching methods of installing the 80 amp option outdoors in a weatherproof enclosure. During summer months my daytime ambient temps routinely exceed 100F. So, I guess I'll be charging at night in 90F temps. Compliments to FlasherZ for your gumption and detailed reporting! I like the idea of PV2EV to move the unit inside. I'd have to build a weatherproof feedthru for the charging connector and cable. That way the FCSP will be inside my air-conditioned laundry room. I'm planning on installing the HIS for home power backup as well. I'll have to re-think things a bit.... Will keep you posted. Thank you all.
But why? Is the fcsp not weatherproof enough?
It is rated for outdoor use, but the EVSE needs to get that initial patch they rolled out shortly after the initial waves of delivered trucks were experiencing premature shut-down due to heat. Now that that issue seems to be resolved it will be interesting to hear reports of reliability from hot weather folks this summer with an outside setup.
Kentrider
My daytime outside ambient temperature is routinely 100F to 110F and, per FlasherZ's realworld pyrometer temp readings, the FCSP performance may be sketchy. My installation site is south-facing with no sunshade. So I'm doubtful the FCSP will survive the UVs, let alone baking in the summer sun. I can schedule the charging cycle for nighttime. However, the HIS that will accompany my FCSP will be needed during daytime for limited home essential circuits - refrigerator and A/C.
Heliian
Ah, I see.
Then yes, to run it at the full 80a you'll probably want full shade on it. Even then, 100 to 110f is on the edge of the 113 deg F maximum temp limit.
I have mine set to 48a and it will charge 20-80 overnight 8-10hrs for an ER battery. For me, the expense of going to 80a wouldn't be worth it but I'm not familiar with the his requirements.
OffRoadRacer
Jesse
F150 Lightning
I am in the exact same situation. I have tried every combo of power cycling and the 3 red buttons I can think of and can’t get it to go into factory reset. Has anyone found a solution for this state?
eyeguy
Terry
Pennsylvania
2013 F150 XLT, 2011 Shelby GT 500, 2016 Fusion
Self employed
Just a thought, why not wire a 12v computer fan or two to activate when charging?
brewski
GA
2023 F150L Platinum
Yes
This is a confidence building thread.
Nick503955
Nick
San Diego, CA
I had an email conversation going with a "Passenger Vehicle Concern Advocate" from Ford Corporate. They are shipping out a new Ford Charge Station Pro.
OffRoadRacer
Jesse
F150 Lightning
Well that’s not the answer I was hoping for! Thanks for the reply
