white lightnin
yesDid you add your truck to your Ford pass account before you took delivery?
Try removing it from your account and re-adding it.
yesAre all your connected services working? Blue cruise, connected nav, blue oval charge network?
Give Ford a call next week: (800) 334-4375 maybe they can assist.
Took delivery of my Lariat ER today. Set up phone as a key tonight. Left the key inside and took the truck for a spin with only my phone in my pocket.Phone as a key (PAAK) isn't available yet. There will be an OTA update at a later date to enable it. Nobody knows when this will happen.
What software version are you on?Took delivery of my Lariat ER today. Set up phone as a key tonight. Left the key inside and took the truck for a spin with only my phone in my pocket.
To set it up, I sat in the truck with the actual key and turned it on. Then I followed the prompts on the Ford Pass app to activate. Pretty simple.
Your truck doesn’t have Paak enabled yet.I don't have that.
hope Ford doesn’t do what they did to the early f150 and mach e builds. Took them forever to get the updateIt was discovered this afternoon - there is a SW update for a module needed. It is apparently being included in the recent trucks and the rest of us will get it as an OTA update. The FDRS gurus compared trucks and modules - their info is here: https://www.f150lightningforum.com/...uck-using-just-the-passcode.11931/post-254649
Either you have it or you will have it - when ever Ford wants you to get it. If you don't have the prompts - then you don't have it yet.
There are some OTA update issues as we speak. There were a few Power Up updates in early August. Some are still waiting on a couple of those. The software is downloaded, but the updates aren't triggering. I think I can say it is a known issue by Ford. I don't know how long before we see it finally get triggered or fixed though.
I would believe that as those get remediated and Ford completes all of their testing that this module will be pushed to all of us and then we'll all have PAAK working.
PS - If you don't have or know what FDRS is, it is a tool to update SW in your truck outside of Ford's OTA pushes. It can be expensive and if you don't truly know what you are doing you can brick your truck.
I received my Lariat ER on the 26th of August and once I set it up (followed the prompts on the screen) my PAAK has been working flawlessly.Phone as a key (PAAK) isn't available yet. There will be an OTA update at a later date to enable it. Nobody knows when this will happen.
It is being reported as working fine on many Lightnings delivered in the past couple weeks. And apparently a few wizards on this forum with older trucks got it to work using FORSCAN tricks.Phone as a key (PAAK) isn't available yet. There will be an OTA update at a later date to enable it. Nobody knows when this will happen.
I don't think that is right. I believe you should have got 2.I only received one key fob.
