Android auto making outgoing calls not working
Deleted member 12322
Guest
Last follow up with Ford, Sync team expects a solution with a future update. The CS rep said to expect one by the end of March, she made it seem like that may resolve the issue but I'm not sure that's 100% true. I guess we'll see what we get later this month. In the meantime, switching from a 21 to a 23+ certainly has been better. My 21 had Bluetooth issues with multiple things, now it seems a lot better without having an issue in the last few days.
BennyTheBeaver
I'm not an amazonian customer, so you're saying my XM/Sirius is the root problem in my use case?
I know this is a couple months late, but it isn't XM that is causing the issue. I have the Android Auto call issue in my Pro (which, thankfully, doesn't have XM equipped).
Aschool
Adam
Appleton, WI
2022 Ford F150 Lightning Lariat
Electrical Industry
Has anyone had any success with this one? It has now gotten to the point where I can make two, even sometimes three attempts before being able to hear the dial tone. So frustrated because aside from this issue, Android Auto has been great.
sotek2345
Engineering Manager
My solution has been to either call while walking to my truck, or turning off the phone Bluetooth and wireless and using speakerphone while not connected to the truck. Not the best options.
OrangeCrush
Alpharetta, GA
2023 F-150 Lightning Lariat Antimatter Blue
Still waiting for a fix @Ford Motor Company . This is getting really annoying. Every first call I make in the truck has this issue. How they missed this very basic thing in QA testing baffles me!
Amadj
NJ
None Yet
Still waiting for a fix on this......has anyone been able to fix it?
USA EV
Any call of any reasonable duration in my Pro ends up with audio issues. The most common is suddenly not being able to hear the other party, but they can continue to hear me. Switching (on the phone) to speakerphone and back to BT will allow me to hear them again.
Second most common is audio distortion when the system gets overloaded like when it needs to play a new sound or switches apps. This is very common and not just audio for calls.
Storm Breaker
Norm
truck driver
just adding on so ford does something about this. i too am currenly having this AA issue with incoming and out going calls
Turn off WiFi on your phone.
I've been having issues as it's trying to connect to the internet instead of using data.
Android auto was trashed at the last update too, the map blocks the top half of the screen for no good reason.
nanohead
Dan
NJ/VT
21 Mach E, 23 Lightning ER, 15 F150 XLT, 12 Cayman
There still no fix for this bad functional defect to basic phone operation via the in car infotainment system. It is clearly a Ford problem, not a AA problem. I use AA in a variety of cars and only in my Lightning and Mach E do we have this problem.
Google is sloppy as hell with their testing, and Android Auto is wildly inconsistent from release to release. But this basic ability to make an outbound call using the in car system is terrible,
FWIW, this has zero to do with Sirius, wifi, or any other bigfoot/space alien issue. Its some kind of audio handoff problem with how Ford implements bluetooth control of audio channels in its current Sync implementation. It also has zero to do with the kind of car, ie, Pro vs Lariat, etc. Happens identically in our Mach E......
I love the Lightning, but I dread using it some days, as I need the time in the car to make phone calls, and I just can't.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hey there. I can look into your Lightning’s Android Auto concerns on my end if you’d like. Will you send us a private message with your VIN and dealership info?
sotek2345
Engineering Manager
Just chiming in to save I have the exact same issue using both AA and just connected via bluetooth without AA. Doesn't matter if I am plugged in or not. Takes 3 to 4 attempts to get a call going.
96161Lightning
NorCal
Volkswagen ID.4, 2022 Lighnting Lariat ER
I'm having similar issues, most commonly losing ability to hear the other party and having to toggle Bluetooth on and off, especially when I initiate the call. Also if I am on a call before I get into the vehicle and then start up, the connection typically works and the call transfers, but then after 30-60 seconds I lose ability to hear the other party and have to toggle.
Peddyr
Peter
New Hampshire
2022 Ford Lightning Lariat SR
Cyber
This isn't just an AA issue. I have the same thing with my iPhone. Make or receive a call and after a few seconds, I can't hear the other party. I have to put the phone on speaker than choose the F150 option again to hear it through the truck speakers. @Ford Motor Company this isn't an individual issue, it's a Ford software issue. Would be great if you could look into the solution and provide us with feedback. Thanks.
Prime8
Aaron
San Francisco
Colorado
Construction
Chiming in here also to say I have the same problem, very annoying and inconsistent. I'm a contractor so I'm very frequently on my phone in my truck throughout the day. Hoping for a solution soon...
