Ventorum94
I think it’s difficult to make a load calculation based upon specs on labels of motors, heaters, etc., as they do not reflect age/condition, or the specs of any previously-replaced components; whereas, taking an actual current measurement reflects all of the unknowns. True, you’d probably never see an “everything-on” load- but you could say that’s the safety margin…That would result in a load higher that you would come up with doing an NEC load calculation due to the load diversity factors used in the calculation.
If that measurement says you’re good, you’re good, but if it shows not enough remaining capacity, it’s possible you’re still OK.
