I usually get all the updates to install but having issues with the RAD-PS one. Thanks to a forum member that looked up my VIN in PTS it shows failures due to 12V battery SOC. I have idled/driven truck to get to 85% SOC (per Car Scanner) and still no go. Lots of attempts. He suggests external charging and resetting BMS. I've read through a few posts but want to make sure I'm doing it right. My questions:
[EDIT: Updated with answers from following posts]
1. Can I charge the 12V battery using the jump start points under the passenger frunk cover?
YES
Or connect directly to battery terminals?
Can connect to directly to positive terminal. Cannot connect directly to negative battery terminal. Must connect downstream of BMS sensor, see below for locations.
Do I have to disconnect negative cable if charging at battery?
NO
2. I plan to buy the Clore 20A charger/power supply in case I want to go with FDRS in the future. Should I charge at 2A, 10A or 20A?
I used the Clore PL2320 charger on 10A AGM mode and it worked fine. Others have used 1A or 2A chargers with success. Note it will just take longer to get the battery to 100% so allow for that. Suggest that you buy a charger that has AGM selection for best operation. The NOCO Genius line of chargers gets good reviews on here. I liked the specs of the NOCO Genius 5.
3. I presume I do the BMS reset after the charger has charged the battery fully, right?
Do not do a BMS reset. It won't be needed if the LVB is fully charged.
If not using the jump point under the passenger frunk cover (requires twisting about 10 clips), you can easily remove the battery access panel at the back of the frunk and connect your charging clamps per this pic:
On the left the blue circle shows a lug that is downstream of the BMS sensor (the black box in front of the actual negative battery terminal). You can connect your negative clamp here. On the right, pull back the red plastic cover and connect your positive clamp to point circled in blue. Do not connect to the points with a red X. Note both these locations have a M6 stud so if you have a couple of M6 nuts you could attach ring terminals. Chargers like NOCO have clamps that can be converted to ring terminals for a more permanent hardwired connection. There is an alternate Negative/Ground location shown in the Police Modifier Bulletin. I did not check the thread size, possibly a M6 as well. Here is a pic from that:
Finally note that there are orange-colored cables that you will see when opening either the battery panel or jump-point frunk cover. These are the High Voltage DC cables that you need to stay clear of. They are insulated but don't go around probing them with sharp objects!
Also if you touch the 12V battery terminal while also in contact with the vehicle frame, you will get a tingle or buzz that may make you do something you didn't want to do. I'm just careful that I am sitting on the rubber frunk mat and not touching an exposed metal part of the frame when messing with the positive terminal and cover.
YES
NO
