itdwebman
Is it possible to check is any modules have anomalies that might prevent updates? Ford OTA Team told me that my 23 Lariat ER never received an update - even at Ford. Mike G helped me out by indicating some updates were ready. If and when I contact my dealer want to be ready with actionable info.Not to step on @Mike G 's toes or anything; I don't know if he has access to PTS to check the details for these kinds of things. A screenshot of your OTA dashboard is below. 4.2.2 shows that it installed successful back on 4/6; that is the APIM update you see close to the bottom of the list. 6.1.0 show it installed successfully on 10/17. On 10/26, you were sent 6.2.0 which PTS shows it failed to install, but there is no error code provided to give any insight as to why it actually failed. It is not the first time I see an update fail without an explanation as to why it failed. The OTA failed before the manifest was posted for your truck to verify the files are correct and start downloading them. As far as getting OTA's sent you goes, I don't see any reason for you to be concerned. I am sure 6.2.0 will get resent to you sooner than later.
Vehicle history shows several modules on your truck were updated on 9/29. Warranty history shows your truck was at the dealer around that time, so I assume the dealer did these updates. The modules that they updated are below. This is important to your concern because these module updates could very well be tied to certain OTA's that you will either a) no longer receive because you already have them or b) will fail if the OTA gets sent to you because you already have them.
Now, why your truck is saying that 4.2.2 failed after a Sync reset is beyond me. However, weird things happen. My own truck says the last update I got was 4.3.6 and PTS shows that it failed. That update is a PCM update which would have wiped out my tune had it gone through, so my truck saying 4.3.6 went through successfully is a lie. I have pulled the files from my trucks PCM to verify I still have the old strategy, so the update for sure did not go through. Personally, I would not stress the fact that your truck is saying that 4.2.2 failed now 6-7 months after it installed.
Thanks in advance.
