Ford Charge Station pro
BeardedOneGaming
BeardedOneGaming
Connecticut
2014 F150 XLT
Ever since I got my FCSP installed I had a hard time getting it connected so I could see it through my FordPass app. Had the installer Sun Run recommended even try when they installed it and they had problems and tried calling Ford Customer Service.
This past weekend I decided I wanted to try again so I could start tracking the charging amounts. I tried several times and there was not a wi-fi for the FCSP that was broadcast. Reset it and that didn't work. Kept trying and eventually the SSID showed up and I was able to set it up. I then attached it to a closer router I have and so far it has stayed connected so I can view it on my FordPass app.
I had to keep trying it for about 10 times to see the SSID on my phone, even trying to enter it manually with the password. If it ever disconnects I will probably have the same problem getting it to show up. Not very robust.
Where is the reset button?
BeardedOneGaming
BeardedOneGaming
Connecticut
2014 F150 XLT
Your FCSP might have stopped making its wifi visible. It typically does this after you connect to it during pairing setup. You can open up the case and hit the reset button to make the SSID visible again. I had to reset 3 or 4 times before pairing was successful.
Thanks @TaxmanHog, had a busy weekend with kids' (yes plural) birthday parties and forgot to get back here after seeing the email notification.
