Beaux
i used to see over 18 regularly and had to keep it turned down due to over heating. Now it can take around ten hours to charge up when I’ve ran it low. One time it didn’t charge up before I needed to leave again the next day.Assuming you're viewing the rate of charge the Fordpass app, my FCSP dialed in for 80 amps, usually show no more than 16KW, but when I look at my Emporia Vue2 energy monitor for the FCSP 100 amp breaker it's showing high 17.x KW sometimes as high at 18KW, never have I seen 19.2KW the theoretical maximum.
When you see it running under 14/15 KW, are you attempting to charge to 100% SOC, or is this happening constantly at lower SOC values?
I have the truck set to charge to 90% daily as recommended and only charge to 100% for trips.
Currently most EA chargers that I’ve been on stay under 120kw where I used to average around 131kw.
