sstevetx
Steve
AI_V, in the FordPass app click the "Service" tab at the bottom and then click the "Customer Satisfaction Program" tile. You can also check on their website https://www.ford.com/support/recalls/
Al_V
Allen
Canton, Ohio
Thanks, but I don’t have that option in the app, and nothing shows shows up on the webpage.
is that because this CSP is not yet applied to my truck?
I do have one of the part numbers.
Ford F-150 Lightning CSP-23B70 Certain 2022-23 F-150 Lightnings - BMS Sensor Replacement 1704640664983
Ford F-150 Lightning CSP-23B70 Certain 2022-23 F-150 Lightnings - BMS Sensor Replacement IMG_7499
Ford F-150 Lightning CSP-23B70 Certain 2022-23 F-150 Lightnings - BMS Sensor Replacement IMG_7500
Ford F-150 Lightning CSP-23B70 Certain 2022-23 F-150 Lightnings - BMS Sensor Replacement IMG_7501
The Weatherman
Dean
South Central KY
I too no longer see the CSP block on the Service page within FordPass App.
I’m running 4.32.0. Is this me (and few others) or has something changed recently?
itdwebman
Northeast
I got the BMS CSP. This might explain why no updates have been pushed to my truck. Not to see if my "non-EV certified" dealer can replace it on Friday? hope I can call them to order the part.
The tiles are [DYNAMIC] if all issues are resolved the tile goes away, this happened after my wiper motor & light bar recalls were completed, about a week later the Recall tile also disappeared, checking the WEB page version, they are no longer listed.
OTOH, my CSP tile is still active though the BECM update has been done, and now the LVB BMS matter as well.
The Weatherman
Dean
South Central KY
That makes sense. The problem is I have two outstanding CSP’s and still show in my account on the Ford.com webpage.
Frustrating. 🙁
Frustrating. 🙁
I should have been clearer, the Fordpass tiles come and go, but the FORD.COM links are always visible for Recalls and CSP's even if there is no open issue, as is the case for me under recalls, but my BECM was addressed already but it remains as an open issue under CSP's that others say will be visible for a year past service date.
Revenge
Ryan
2023 Lightning Lariat SR, 2011 Flex
It's funny how not until this post comes out have I had any issues with my LVB. Yesterday I got a notification about a drain on my LVB and needed to plug into charge. Low and behold my BMS is one that needs to be replaced.
Maxx
What is the highest SOC for 12V have you guys seen through a scanner recently? I don't seem to be able break 80% but I don't do long drives and my charging sessions are only 20% for high voltage battery.
Also do you know what the voltage at cigarette lighter or battery has been for the SOC you measured? or do you have a chart for our battery that translate cigarette lighter voltage to SOC accurately?
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
I have been monitoring FORD.com for my LVB twice a day since Dec 26th. Highest has been 98%, lowest 86%, most are around 90%. I have received the CSP notice too. I have had long drives, short drives, 1 DCFC, mostly 240V AC charges.
sstevetx
Steve
I have the CSP notice and have the "AC" model. My dealer's mobile tech is coming out later this week to replace it.
Got a call from Utter, will be here Wednesday at 1 - is that who you use also?
sstevetx
Steve
Yes, it is Utter
lipnorth
Connecticut
2023 Ford 150 Lightning Lariat
I got a notification this morning to schedule service for this issue. Have to wait 2 1/2 weeks.
Does this issue prevent me from getting OTA updates? So far I haven’t received any OTA Updates and I’ve had the truck 6 months.
