Cold Weather affects on our battery - does FordPass app adjust for it?
1Jetpilot
1Jetpilot
Jerry
Port Clinton, OH
2023 F150 Lightning Lariat ER
Retired Pilot
My app shows updated GOM based on temperature.
Another reply to me was to multiply Miles/Kwh NUMBER times the Battery PERCENTAGE to arrive at your 'true' miles-to-empty conversion
So, you are alleging that 85 miles is Ford's best range estimate based on outside temp?
Yesterday it showed 60 miles @ -20°F. It's -8°F currently.
I believe you, seen this myself, but Pioneers point is that the mystical lie will rear its ugly head if you bring up the SOC from 60% to 80% or higher, that's what Jerry is trying to reconcile.
Bingo.
AZT9
Peoria, AZ
I’ve gotta say. The CarPlay mapping Integration has been very reliable to within 1%. I can’t say for sure but it seems to factor in terrain and weather in its calculations. I map my way to work every day even though I obviously know where work is, but to see what Apple Maps calculates and it’s been very reliable for destination percentage.
Word of caution - until you put a destination in and start driving for a while, that number can be wildly inaccurate.
Right now it is -4. My garage is 22. I can guarantee that the projected range is NOT using -4.
Air needs to flow over the temperature sensor to give it any semblance of accuracy.
While I have close to 30,000 Mach-E miles, the only highway trip with the truck was on the way home from the dealer 3 states away. I got 1.8 in rain. Figured I would have got 2.0 in nice weather. Winter is a 20% hit at least, so 1.6. People are posting they are getting 1.4, because this isn't 20, it is zero. 30% hit. Totally in line.
1Jetpilot
1Jetpilot
Jerry
Port Clinton, OH
Retired Pilot
I would use 30% hit as a winter standard
F150ROD
U.S. Navy Retired
Last summer I took a trip to Vegas, charged to 100% and had a total of 325 miles of Range. Once I set the destination in the Navigation system, it quickly adjusted to 234 miles of Range. It was spot on.
Ford F-150 Lightning Cold Weather affects on our battery - does FordPass app adjust for it? IMG_2564
Ford F-150 Lightning Cold Weather affects on our battery - does FordPass app adjust for it? IMG_2565
StaggerLee
Austin
Lightning ER 2023
Long time lurker here - 1st post. Currently charging outside (17F) while reading this thread. I opened up Fordpass and was at 79% with 167 mi DTE. Now a few mins later it's at 80% and 238 mi DTE. Pretty good jump for just 1% SOC! 2023 Lariat ER.
N0v0w3ls
Western NY
2023 Lightning
Mine is currently at 88% and shows a range of 205 after refreshing. When I first pulled it up, it was showing 180 before refreshing so it seems to be adjusting (Lariat ER)
I had the truck plugged in until around 5:30 pm last night and had it at 90%. I needed to move the truck and so I it was unplugged all night and when I started it this morning it was still at 90% but the battery was at the low end of the temperature zone and I only had 84% of maximum motor power available.
