Nftypjs
Correct.I assume it is this one:
My "Charge Level" is indicated in milage. This is my first time seeing this online dashboard so maybe I need to change something? Zero update since purchase in Nov. 2023, so it hasn't been that long and I did receive the letter for the 12v charge indicator replacement.Go to your Ford Account Dashboard on Ford.com
The mislabeled square reads "charge level" in the center. That isn't your HVB, but your LVB
While logged in, goto your account status via this link to see the "Charge Level" aka 12v SOCMy "Charge Level" is indicated in milage. This is my first time seeing this online dashboard so maybe I need to change something? Zero update since purchase in Nov. 2023, so it hasn't been that long and I did receive the letter for the 12v charge indicator replacement.
https://www.ford.com/myaccount/?gnav=header-account
My 23 is also has zero updates. Does this AM radio update have anything to do with it? It made me curious since they stopped pushing updates to new builds around the time the lack of AM radio became an issue. This article claims the AM radio OTA is coming soon……. https://fordauthority.com/2024/01/2023-ford-evs-are-getting-am-radio-functionality-back/Your truck has not recorded any updates. It is on Sync 22326 which is the same software it left the factory with when it was built in June 2023.
@davehu. Also, if you look at FordPass and it says "last updated 18 hours ago," the Ford.com data on LVB %SOC will be stale. It helps to refresh FordPass (sparingly) before you go to the referenced dashboard showing LVB SOC. RickLightning says refreshing FordPass or being near the truck with your fog or your PAAK wakes the truck electrical system up. Too much of that will contribute to LVB battery drain with the truck just standing around, according to Rick.Go to your Ford Account Dashboard on Ford.com
a mislabeled square. Huh. so after reviewing this thread I see why I'm confused and suspect many others are too. I loginto my ford.com dashboard a couple times a week at most. I go to ford.com and then from the pulldown menu select vehicle dashboard. and I see this:Go to your Ford Account Dashboard on Ford.com
We could call it a "Glitch" or poor designed tab label, by inference, of seeing the mileage one assumes the same pixel location with different label is the HVB SOC for those miles, unfortunately it's not, it is the LVB SOC.as you can see both screens are using the same information, or so it seems until you look at the data presented under "charge level" on the screen I have been using for 4 months it gives the GOM mileage. but on the other it shows a percentage. another software glitch from Ford IT. but thanks to this thread I have learned something.
No, I don't have a good explanation as to why you aren't getting sent updates, but that AM thing I am sure has nothing to with it.My 23 is also has zero updates. Does this AM radio update have anything to do with it? It made me curious since they stopped pushing updates to new builds around the time the lack of AM radio became an issue. This article claims the AM radio OTA is coming soon……. https://fordauthority.com/2024/01/2023-ford-evs-are-getting-am-radio-functionality-back/
Hmmm…. I’ve seen this mentioned before, but every time I check, the % shown on the dashboard page matches my HVB. ???Go to your Ford Account Dashboard on Ford.com
You have checked the info in post 68 above?Hmmm…. I’ve seen this mentioned before, but every time I check, the % shown on the dashboard page matches my HVB. ???
Log into your account on Ford.com. The vehicle dashboard will show SOC in miles. Click on ABCD’s account. Look at that dashboard for LVB charge level.Hmmm…. I’ve seen this mentioned before, but every time I check, the % shown on the dashboard page matches my HVB. ???
…Could this have something to do with my BMS sensor that still needs to be replaced?
Yep, have checked as in post 68.You have checked the info in post 68 above?
Perhaps your state of charge you keep your high voltage battery is very similar to your current status of your % of charge of your 12 volt battery?
