Weak LVB?Is anyone else having issues getting 6.8 installed? My install keeps saying it failed due to a prior process?
I have had two updates give me fits (RAD-PS and 6.8.0). They both finally installed after I was plugged in to the L2 charger for several hours when it did the scheduled attempt at 1 am. Also lost a lot of blood. For RAD-PS, I had on both a 12V charger and the L2. Maddening.I think 6.8.0 tried about 20 times on mine. It took about a dozen runs at it in December, then paused, then tried again 7-8 times in January before it finally went through. If I had to guess, I'd say 6.8.0 doesn't like it if the truck is actively L2 charging. It also doesn't like it if you try and update manually from the screen. When mine finally went through, I was not connected to an L2 charger, I had a trickle charger on the LVB (topped right up to 100%) and left the truck to do the update overnight on its own. Not sure how many blood sacrifices I made during the process.
Agree. It ONLY charges while the HVB is charging. I also don't understand why the updates don't trigger the DC-DC charger to top up the 12v battery before the update. Update pending, truck plugged in, top up the 12v battery first before attempting the update and eliminate the drama. Seems simple.i'm in the same boat. have tried 6.8 update over 2 dozen times under different charging scenarios. i have not measured 12v battery yet, nor have i gotten my battery module looked at yet (part of the service bulletin). i am hoping this is an issue w/ the LVB, as all prior software updates worked for me flawlessly.
i still dont quite understand why the LVB cant trickle charge when L2 is plugged in.
Ditto hereMine went through no issue about 7-10 days ago. I have not had 12v battery module replaced yet. I was plugged in at home but not actively charging.
