Priority Update: 23-PU0813-DOR-UP2
Peddyr
Peter
New Hampshire
2022 Ford Lightning Lariat SR
Cyber
Got the one for the doors last night. Everything went smooth.
A work in progress, hoping my peek at the app doesn't cause a failure due to "process interrupted", but maybe FP 4.33.0 is smarter about blocking probes while an update is in process?
Ford F-150 Lightning Priority Update: 23-PU0813-DOR-UP2 1710854276133-p9
F150ROD
F150ROD
U.S. Navy Retired
Hopefully it goes through without issue!
Still nothing for me, I just want my Blue Cruise back.
Looks like I got it without a problem.
Now to test remote start to see if this might have also fixed my heated seat & wheel issues, though it's not a specific target for this update.
Ford F-150 Lightning Priority Update: 23-PU0813-DOR-UP2 1710856407164-o
Ford F-150 Lightning Priority Update: 23-PU0813-DOR-UP2 1710856378317-l5
SmoothJ
New Jersey
2022 F150 Lightning
I was prompted to install 23-PU0813-DOR-UP2 after my commute to work. So now I am just waiting for it to install and we will see what happens.
EDIT - it installed successfully.
Warp Asylum
Austin, TX
2022 F-150 Lightning Lariat ER, 2023 Mach-E GTPE
This queued up on my way to work today after getting 24-PU0105-CMR-FX yesterday. I'll install it when I get home.
Keep 'em coming...
Edit: installed after work with no issue.
Whammy Bar
1971 F100 + 2022⚡Lariat ER
  • Haha
I also peeked at the app during this update without issue but I make sure BT is turned off so PAAK doesn't interfere. The app will let you know PAAK is not working (wants you to optimize) and controls are grayed out)
Y'all need to start livin' on the edge. I installed 2 updates last night with a LVB sitting below 40%. I was getting no app messages, so I opened the app a couple of times to check on it.
Now please let me keep being on the front end of these releases and not have to tow this truck because it gets bricked. I'm going to take the positive route here and say that Ford has made some headway since December on getting the SW installs to smoother.
I know we've still had some reports of failures, but with all the '23's getting caught up and I believe many fewer reports of failures, I'm going to give them some props.
Totally agree, things are moving more smoothly.
Side note: Afternoon run, truck was warmed inside by lots of solar heating, though the outside temps was around 48°, remote start ran and switched the AC and chilled seat mode on to cool down the cabin.
Remains to be proven if the warming routine is working, probably test that tonight or early Wednesday morning, spring weather suddenly disappeared as we're approaching the vernal equinox at 2306 hrs this evening, more freezing weather in the next few days :(❄☃
Strap your seat belts on for the mass post move to primary topic thread.
MOVE COMPLETED
