Ventorum94
[sigh] An ER pack is 30% larger (a nice upgrade, but not an end to range anxiety). Most people maintain SOC between 20%-80%; if you operate your SR between 10%-90%, you have 3% more range than an ER maintained at 20%-80%, and you’ve probably saved $12k and 300lbs less mass to haul around. Faster L2 charging on a ‘23 ER is only possible if you can put in a 100A circuit for a FCSP (most people don’t have that much available in their panel, without expensive upgrades). And finally, the lower DCFC rate per the original SR specs hasn’t proven to be accurate, with SRs fastcharging at essentially the same rates as ERs.A 23 ER will beat a 24 SR for range even with the heater at full blast the whole trip. Plus faster L2 charging and incentives no question get the ER
-Zap
