Just finished my test with truck being plugged in, charge had completed a couple hours prior [12.6 kWh], then let it set until around 5:30, started the remote climate session with the following features switched on [cooled seats], prior to parking the truck I confirmed my trucks basic setup is remote start permitted with 15 minute cycle time and automatic conditioning of cabin / seats / wheel. While the main HVAC console showed Auto-3, AC on/available, last used seat condition was cooling-3.Thanks for the reply, I'd love to know if it can be replicated. My trim is the sync 4a lariat
After letting it run for 15 minutes, I went out to see if the seats were cold or hot, found them to be chilled nicely, pressed the START button to full run status, Sync screen confirms that seat cooling fan-3 active.
Interestingly this fifteen minute event pulled in 1.5 kWh of energy over and above the initial charging from 81% to 90%, I suspect the battery ~settled~ during the down time, so the OBCC kicked on for a couple minutes to re-top the battery from a fraction under 90% back to 90% certain, then the remaining energy draw is to replenish the load of the HVAC system compressor, seat, evap and condenser fans.
Just remember most of us are not on consistent software / power-up version, so my truck behaving a certain way doesn't invalidate the negative / less than optimal conditions you have experienced.
