Grumpy2
- Nov 23, 2022
- Central Oregon Coast
- 23 F150 Pro SR
- Occupation
- Retired Hvy Construction
Awhile back Mickey posted: " There are two thermisters (different from a thermocouple) in each module that is read by the BMS."Maybe there is something wrong with the coolant temperature reading furnished by Car Scanner
It will be difficult for any scanner to give a realistic temperature value for the entire "battery" when there are at least 18 thermisters within the pack. It seems the 59 degree number must be wrong if the concrete floor is +20 degrees higher.
