ktom
- First Name
- Kevin
- Aug 15, 2024
- Austin, TX
- F150 lightening, model Y
- Occupation
- Self employed
Hi Lightning owners,
I was on my way to work this past Tuesday 8/27/24 so I got to my driveway and entered my Truck. I then started it the usual way when initially I saw a "Full Accessory power active" sign on the screen. I pressed "OK" then started the truck, but it won't start. I tried about 5 times and still won't start. I googled the issue with Accessory power active and tried the tricks that people used to start their vehicle: I placed a new battery on my key fab, tried the push start only without brake then do break and start together, tested my 12 v battery (was fine), let the truck cool down for 30 mins then tried to start it again, tried to use my ford app to start it and still won't start. Needless to say, my wife had to drive me to work that day. When I came back from work around 8 pm, I tried to start it again and truck still won't start. After cooling it for another 20 minutes, I went back to try to start it again and now the main screen is showing "Update not successful. Unfortunately, a recent software update was not successful. Your vehicle cannot be driven. Please call customer support......". To make the long story short, I called Ford Roadside Assistance, and they towed the vehicle (mind you, took them over 40 minutes to figure out how to get it to neutral because even with the instruction on the screen, it would not do it) to the nearest ford dealership.
Has this happened to anyone else before? My truck is a 2023 Ford F150 Lightning Lariat with 23,000 miles on it. Today is 8/30/24 and per the dealership yesterday, the truck could be with them for another week as they have been having issues trying to update it with the new module. Per the dealership, the truck still won't start.
Thanks for any input you guys may have. I loved my truck. No other truck compares to this in my opinion, but this issue has been devastating.
Lionel
I had a similar issue, at least with the first screen, but my result was different.
I had gotten the update the previous night. It was a hot hot day, >100. I had parked and gone inside at my sons apartment, I came out to get the same message, pressed OK, nothing. Went through this multiple times, and the truck wouldn't start.
I called the ford pass people and after sweating for 15 minutes, convincing them that I was the owner. The solution was to go outside the truck, lock it with the key fob, wait until the truck had competed the lock sequence, the unlock with the key fob. It started/turned on! Yea!! Too simple, not very obvious, but a sequence I will remember. I always have the key fob with me but rarely use to lock or unlock
I too have had the truck in service for a new module that took a week to install. The first issue was the 12v battery was bad. After they figured that out it went faster.
I am sorry that yours is bricked. I hope that they get it figured out soon. The software either in the truck or in the app, seems to be the weak spot for these vehicles.
