Where are the Tesla chargers?!
jlferg0509
Dayton
2015 Chevrolet Malibu; 2023 Ford F-150 Lightning
Why am I still not able to see Tesla chargers when planning a trip?! There are different areas, that this fails;
  • If I plan a trip, the native Ford Navigation NEVER shows a Tesla charger as an option.
  • If I attempt to manually look up a compatible Tesla charger, that I know is in the area because of the Tesla app, it does not show up in the the Ford native Navigation.
  • I've also noticed that if I try to use ABRP to plan a trip, it leans more towards showing Tesla chargers rather than other distributors. But digress, I'd like to see Tesla chargers as an option when planning a trip. Sometimes they are a more convenient option.
while we can complain that they don't show up in one system, or the other, the best option for the time being is to handle it yourself - Google maps / Tesla's own Supercharger map, etc.
You can also choose to navigate to a building right at the same place as a known supercharger if you really HAVE to have the Ford Nav take you there...
I've traveled up and down I75 in GA and FL, and thru AL, using Superchargers the whole way... several thousands of miles - I never use the Ford NAV.
Ford F-150 Lightning Where are the Tesla chargers?! IMG_8960
Piquette
Trent
New Hampshire
2022 Lightning Lariat
Use FordPass. Click on Energy tab, next click on public charging which brings up a local map and a search box. Type in the location you are searching near (e.g. Batavia, NY), and the Tesla chargers will show up.
jlferg0509
Dayton
Thanks @hturnerfamily, I knew that Google maps shows chargers but haven't really checked it out recently. I assume this would work for me as well as any other tool, when I've arrived in a new area. I've grown to lean on the Ford Native Navigation when on the road because of the integration, although I will migrate to one of the other options if I run into a backup at a charger.
jetfixr1
Manny
Atlanta
2023 F150 Lightning Lariat ER
Hopefully the Ford OTA team is working on adding the Superchargers to the list of updates needed. In the meantime, ill take PIN to drive and dog mode over adding superchargers to the nav.
I'm hoping there will be an update to Ford Navigation to expand the list of available chargers, it's a separate project from the Public Charging app on the Sync screen.
The Weatherman
Dean
South Central KY
Lariat and Platinum have PIN to drive. It’s an aside to PAAK.
davehu
hot springs, AR
I was having the same issues when it didn't show a Tesla charger that I used (with adaptor) only a few weeks earlier. I fiddled around with the filters and magically it showed up. Tried to recreate the problem but gave up. will have to video it next time. As for google maps, I just clicked on EV charging and got a "server error. please try again later." ABRP will list chargers but doesn't let you know if it will work with a adaptor as not all Tesla's are compatible. The tesla app seems to be the only software that's reliable. (just like their chargers)
jetfixr1
Manny
Atlanta
That is different. You are referring to the backup start password that you have to create when using PAAK. PIN to drive pops up on every ignition cycle, regardless if using PAAK or a key fob.
MyJoule
'22 F150 Lightning Platinum
Use the Charge Assist from the main screen
Then Type in the name of the location that you already know there is a Tesla supercharger enabled for people with an adapter ( something you figured out with either the Tesla app or using Abetterrouteplanner) Then the Tesla Supercharger will show up and you can not only see it's location and navigate to it, you can see it's current usage level. like 5/8 or 3/16 etc.
We used that method quite successfully on a recent trip from WA to AZ.
thunderbayterry
Terry
Thunder Bay, Ontario
2023 F-150 Lightning Lariat ER, Mazda MX-30 EV
Thanks Piquette - this works!!!
thunderbayterry
Terry
I have a question about this: I recently learned it is good to use the Ford Navigation to NAVIGATE to the charging station because the Lightning will PRECONDITION the battery for a more effective/efficient charging experience when you get there. Here are my questions:
* Is this true of ALL Lightnings, or only model years 2024 and forward?
* I believe this preconditioning works with the built-in Ford Navigation - does this work if you use Android Auto or the Apple navigation?
Thanks in advance to all the knowledgeable followers on this forum - I learn SO SO much here! Thank You!
All model years of Lightning.
It does not work in android auto,
I do not have Apple navigation, can't answer.
