Has Anyone Had Ford Dealer Install Walk Away Lock (WAL) by Installing BCM Update Through FDRS? If so, how and was there a cost?
ziptbm
'22 MME GT & '22 F150 Lightning Lariat ER
Question is in the title - Has anyone successfully had a Ford Dealer install Walk Away Lock (WAL) by installing the BCM update in FDRS that requires the NASTF username/password?
If so, how did you get them to install it? Was there a cost? If so, how much?
It's amazing to me how little the Ford Dealer Technicians in my area know about module updating on these vehicles. Especially given how close we are to Dearborn...
First the tech at my local dealer told me they do not have this access and it's not something typically done by dealers....after pressing further, they agreed to contact their Ford Engineer rep and would get back to me... I'm not optimistic this will go anywhere, but I'm willing to pay to get WAL enabled on this vehicle if I can find someone able to.
Any other suggestions here?
And if anyone knows of a dealer in SW Michigan that has knowledge of this update, please share. Thanks!
They should be charging a half hour of labor; no more than one hour of labor at most. The BCM update takes less than 10 minutes to do.
ziptbm
that's a good benchmark....now if only I can find someone at a local dealer that actually understands what I'm after and can actually do the work.
As long as it is customer pay, I don't see why any dealer would say no.
Maineiac12
Iowa
One thing that might work is if you have an open CSP for a software update on another module you could ask the tech for a favor since they’re already doing FDRS updates. You might get it for free, or you might get charged a small labor charge. I think they even do this with mobile service.
ziptbm
that’s exactly why I called to ask. They just don’t know anything about this special login requirement.
Maineiac12
Iowa
It’s probably because they don’t need a special login. It may not even prompt them if they are using a dealer login. I would just say you need a BCM module update and not even mention the login.
Runaway Tractor
Yes
Because Ford has directed their dealers not to install any software updates unless it is to resolve a documented problem. If you walk in and ask to have your software updated simply because you want the newest stuff, they are supposed to tell you no and to wait for OTA.
Was this communicated to dealers with a GSB that I maybe didn't see?
I asked the tech that came out for mobile service for the Sync recall if he would go ahead and do the BCM. He did and I have WAL. This dealer's mobile techs have been good about doing extra modules within reason and if they don't have another appointment.
I had to add the sliders in Sync myself with FORScan. He didn't update the APIM.
Adventureboy
I got WAL with CSP 24P56. It came out of the dealer with it active. There is no switch to turn it on or off in the settings like my wife's MME, but it works.
The switch will come with a future APIM update, or you can add it yourself with FORScan.
Adventureboy
Thanks, that's my understanding as well. The dealer said they updated the APIM but I'm guessing they didn't have the most current version. I've played with FORScan for a few things but I don't need the switch as long as it works.
I'll probably bite the bullet someday and get the Mongoose.
