FCSP refuses to charge at set amperage
BSull
Robert
Mesa, AZ
Corvette, F150 Lighnting, Mercedes GLC300
Progress! I turned off FCSP again waited a few then back on, turned off scheduled charge times in truck then waited 15 minutes and plugged in. Charge started immediately and climbed to 16.5-16.6kW after a few minutes (about 69A) and stabilized still not at 80. I'll check lugs inside disconnect and FCSP to make sure torque is correct and yes I'll turn off at breaker. I'll check voltage at FCSP and disconnect after checking torque. Probably not today, my inch lb. torque wrench hasn't been calibrated in years but I know where I can borrow one for tomorrow.
Awesome, I've never gotten higher than 77 amps.
I've seen rate taper off at high SOC's not sure that's impacting your situation.
It might still be off calibration a bit.
Refactoringdr
Don
Albion, IL
F-150 2023 Lightning Platinum (ER)
Yep, anytime I've tried to change the amperage via software on the FCSP, I then would have to reboot it twice (via breaker) to get the new setting to stick. Lovely firmware.
BSull
Robert
Mesa, AZ
State of charge right now is 76, that might be part of it. I'll get it lower before proceeding.
Yes, the truck is what requests a certain charge rate/amperage via communications with the FCSP.
The FCSP follows the orders it gets from the truck.
The app settings are relayed to the truck via Ford servers (I believe) but there can be a delay or even a failure to change them when you use the app to do that.
To clear them in the truck is the most reliable way I believe.
So if you had set the truck to charge at a slower rate via the app, that information seems to be sticky in the servers, that is, it doesn't want to change easily, and some have only been successful it seems by deleting the saved location/charge time/departure time settings in the truck and then re-entering them.
I think one of the previous posts had suggested that?
Glad it worked out.
Personally, I never use the app to change settings for charging - the app never successfully added my FCSP to FordPass, always hung there, but just as well as I have seen posts like yours before where the app failed to reset the charge parameters.
PS: it is my understanding that if your FCSP dial is set to a particular amperage and you have not lowered the requested amperage with the app, the truck will default to the max the FCSP will provide based on the dial and the truck - an ER battery truck 80A and the SR battery truck 48A. So using the dial is the sure-fire way to change the amperage the truck will charge at.
The Sync Charging App has no control feature for the AMP rate, I wish there was one but it's NOT A THING with Ford's
