That is not a thing, "a joint CCS/j1772 to NACS adaptor". NACS uses the same pins for AC and DC charging, which means passive adapters (the only kind made) have to be for AC or DC - not both .Easiest solution is to by a joint CCS/j1772 to NACS adaptor and then use the NACS to J1772 adapter.
Maybe you should learn to do research and have facts before you spew off your nonsense and uninformed statements.That is not a thing, "a joint CCS/j1772 to NACS adaptor". NACS uses the same pins for AC and DC charging, which means passive adapters (the only kind made) have to be for AC or DC - not both .
Oh, dear God. Some fly by night string of random letters Amazon bottom feeder made one. You're right, I didn't know.Maybe you should learn to do research and have facts before you spew off your nonsense and uninformed statements.
CCS1 & J1772 to Tesla Charger Adapter for Tesla Model Y/3/S/X: 250KW DC Fast Charging Power, Compatible with Tesla Vehicles. Supports 500V DC/AC EV Fast Charging, Suitable for Fast Charging Stations
https://a.co/d/gjE7vKZ
I wouldn’t use it either, for those exact reasons, but they do exist….just like big foot.Oh, dear God. Some fly by night string of random letters Amazon bottom feeder made one. You're right, I didn't know.
Do not buy this. It shorts together the DC and AC charge pins inside the adapter. It is fundamentally unsafe.
Tesla cars can safely use the same pins for DC and AC charging because they have an extra set of internal contactors. This can't be done safely with a passive adapter. There are many ways this is not safe but the simplest to grasp is that if you plug a J1772 cable into this thing, you get 240V on the DC charge pins that are protected only by that little fold-down flap.
Unsurprisingly, this adapter does not appear to be UL certified.
Tesla cars can safely use the same pins for DC and AC charging because they have an extra set of internal contactors. This can't be done safely with a passive adapter. There are many ways this is not safe but the simplest to grasp is that if you plug a J1772 cable into this thing, you get 240V on the exposed, unprotected DC charge pins.
Holy crap!!!I wouldn’t use it either, for those exact reasons, but they do exist….just like big foot.
That would be the combination, but likely the CCS/J1772 part is a weak link even if it was designed to safely work.So use these two adapters to make it work?
Yeah it is a scary product. But I am sure they will stand behind that bad boy all dayHoly crap!!!
It‘s not inherently unsafe when used with an EVSE or Charger with the combo CCS/J1772 handle, but if you used it with a J1772-only EVSE, you would have 240V AC on the DC pins that could be accessed externally. I could see a 5 year kid sticking a finger in there!
Upgraded 2In1 CCS & J1772 to Tesla Adapter, 250KW SuperFast CCS1 to Tesla Charging Adapter, Fit for Tesla Model Y, 3, S, X, Compatible with Level 1 2 3 Charging Stations with CCS1& J1772 Plug https://a.co/d/3ahCJy8Easiest solution is to by a joint CCS/j1772 to NACS adaptor and then use the NACS to J1772 adapter.
