BATTERY PERCENTAGES NOT MATCHING
Psmith7279
Paul
22 F150 lightning
hello
i am running into an issue ever since I was able to download the latest software 6.8.0
Specifically, I set my charging to 70%. Yesterday as an example, when the charge complete notification it says it is at 100%. Then when I turned the vehicle on it said 100%. Once I put my foot on the break to start the vehicle and drive it said battery was at 64%.
It has been consistent saying charge is at 100% both in the truck and on the app and when I try to fix the percentage slider on the app it will not recognize the change.
Is anyone running into this discrepancy between truck, the different displays, and on the app?
One last note, I just did another charge and changed the range to 80% and within minutes it says it charged to 100% but when I unplugged it, it capped at 64%.
Thank you
Did you have the high voltage battery [HVB] serviced recently, module(s) replaced?
Hi - yes I did. How did you know?
This is a symptom of a repair where the technician did not fully balance the replacement module to the rest of the pack, it'll catch up over the next several weeks, continue driving & charging, requesting the normal SOC you desire, eventually it should stabilize. If it doesn't after a month contact you servicing dealer.
Psmith7279
Paul
22 F150 lightning
I appreciate the guidance and suppor, thank you!
Wonko
Erick
Atlanta
2023 F-150 Lightning Platinum
I have the exact same issue since I had a module replaced last week. Since there is a pack balancing procedure for a reason, are there any potential issues down the road with not having done the proper balancing procedure?
Wonko
Erick
Atlanta
hello
Thank you
I have the exact same issue - also recently had a module replaced. In my case I am set to charge to 90, the FordPass app says 100 after charging, but the truck shows 87 when I power it on.
I haven't read anyone report long term issues since this is all new, IMHO they loosened the procedures to allow the tech's to move the project to closure sooner as a way of dealing workload backed up in high volume workshops.
I suspect the technical team evaluated the minimum safe tolerances and rolled the dice. With an 8 year 100K warranty backing us up I'm not concerned.
Wonko
Erick
Atlanta
I’m not concerned from a financial perspective, but I am concerned from a reliability perspective.
This is the second module replaced on my truck in under 11K miles. This time the fault happened when I went to top up my battery to 100% 2 hours before a road trip. If it had failed one charge later, I would have been 150 miles from home with my family and luggage in tow.
Since it seems multiple module failures is a thing, and since they seem to favor module replacements over pack replacements, I believe Ford should give those of us with module failures additional roadside coverage with unlimited towing and loaner/rental coverage for the duration of the battery warranty.
2 data points aren’t really a trend, but so far my truck has needed a new module every 5500 miles on average.
I know the Ford battery architecture is supposed to allow for module replacements, but the fact that a new module can throw off the BMS this badly and the dealers just let it ride is pretty worrisome.
Adventureboy
I expect the new module was either 36% higher or lower than the others in the pack when they installed it.
I recommend you do a few cycles to 100% SOC. This will help balance the new modules and integrate them with the pack. Also, if you can slow the charge rate, it may give the modules more time to balance before one of them hits 100% and charging needs to stop. The longer the high module(s) sit above 95%, the longer the charger has to balance the low modules so drop your EVSE to 16 amps or so if you can to give the pack more time to balance.
Psmith7279
Paul
22 F150 lightning
Thank you for the advice however, my problem is it won’t charge beyond 64%. It automatically stops at that percentage so even if I wanted to get to 100% I can’t do that right now. I spoke with a technician earlier today to schedule an appointment and he was telling me that you should be charging the vehicle up to 100% at least once a month. I have never heard that before for just normal day-to-day driving I know it’s OK to go to 100% especially for a road trips but to maintain it for day-to-day around 90 have any of you heard of that before with the 22 lightning version that you should be charging to 100% at least once a month?
Adventureboy
I believe you need to set your target SOC to 100% for the balancing to work best. Most of the balancing happens when the highest module is above 95% SOC. Your technician is correct, changing to 100% once per month is good for the pack since it does the balancing. It can improve your overall pack SOH. I charge to 85% in summer and 90% in winter and once per month to 100% (it can take some time to go from 99% to 100% since this is when it does most of the balancing. In my last round, it took a couple of hours to go from 99% to 100% due to the balancing process. In your case, it may take quite a bit longer since the new module is a fair bit out of sync with the rest of the pack.
This morning I charged 90 to 95% early then later started the 95% to 100% phase an hour before roll out, this chart shows the slowing charge rate to when the battery reaches 99% {red highlight}, then energy jumped up for additional battery & cabin warming {yellow highlight}.
I never hit 100% until I pulled the charge cable and started the truck up.
When you're trying to get to the ideal 100% try pulling the connection after it's held at 99% for 10 minutes, see if the dash suddenly shows 100%, if it doesn't plug her in and give it more time, wash, rinse & repeat.
Ford F-150 Lightning BATTERY PERCENTAGES NOT MATCHING 1734227176916-35
