ZSC100
This is one of those situations where pictures are worth a million words. You're using the WAGO connector wrong. Each WAGO connector is fully connected across all ports; so you have essentially shorted all 8 wires together. Just run down to home depot and purchase a bag of 2 port WAGO connectors. Only ever put one wire in each port on a connector, that's how they are meant to be used, but that's ultimately not the issue here. You need four 2 port connectors to do this correctly. Twist each stranded wire before inserting in to the connector ports.I’m having two issues :
1- CCM will not show up despite changing values at IPMA 706-02-02 to from 04 to 05
I’m Getting 2 DTC ( related to IPMA).
Connection to IPMA has been done with correct polarity…
2- One of the changes in forescan I can’t find the correct value in livnitups library… the value is located at the IPMA 706-02-01 according to literature it says I need to only change the first value but the library only shows solutions for 2 values
3 - Also not sure what would be correct value I need to change at IPMA 706-16-01 4th digit in first block
2nd picture shows connection at CCM module
I have a 2024 XLT with 360 camera
