Parking brake set itself after being parked for an hour
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
Parked in my level garage, turned truck off and kept doors unlocked. An hour later I went to get something out of the back seat. When I opened/closed the back door I heard the parking brake set itself (I can't remember if it triggered when I opened the door or when I closed it). I confirmed that the sound was in fact the brake being set. When I later got in the truck to drive it the brake was set and the display had reset to the My View menu (which happens from time to time anyway).
It seems really weird that it would just randomly set itself when the truck had just been sitting there, and even weirder that opening/closing the door triggered it.
The brake otherwise works normal. I don't really consider this a problem per se, it's just something odd that makes me wonder if anyone else has seen it.
Ghosts in the system ..... Yes, I've also experienced what you observed, no clue why this spontaneous E-brake action occurs.
Scorpio3d
SS/IBA car wash owner
I guess that is just the opposite of the old spontaneous acceleration that vehicle supposedly had happen… probably better too!
Perhaps opening the door shook the sensor enough for the truck to consider it now is on a hill??
I think this is right. There's definitely logic that sets the parking brake automatically. I haven't figured exactly what that logic is but something along the lines of "this is a time when the truck shouldn't move" seems about right.
NCevGuyF150
North Carolina
22 Ford lightning
Repair technician
I believe that the truck shook enough to make it think that it was on a slight inclined. Also, most garages, the slab is poured at an angle, so water runs out the door. I do believe the truck is designed for the emergency brake to engage when the vehicle is on a certain percent of incline. Might’ve been a combination of the incline and the truck shaking just enough to warrant the truck to automatically apply the emergency brake.
the parking brake WILL actuate automatically, after a period of time, when the truck is left ON, even if you are sitting in it... it's just a safety protocol. Since I leave the truck on almost ALL the time I have it in use, I see this happen quite often - it does the same on my wife's KIA EV9. Sitting on a hill or rise does not trigger this, it's a TIMING action.
Ricks Lightning
Rick
Los Angeles
Plumbing Contractor
I actually have a slight slope to my driveway, I never have to worry about setting the brake. It does it for me. Which I like.
Now If only the truck will stay in sport mode for more than 2 seconds without me having to confirm and hit the OK button.
Rick
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
Garage slab has a slight incline, I forgot how much but over the length of the truck it might be an inch or two.
Truck had been off for about an hour. I understand it setting when you put put the truck in park when the truck is still on, but why after an hour? Did Ford intend to leave the auto brake active at all times in case the slope changes while parked?? Earthquake protection maybe? lol
In five months of ownership this is the first time I've been aware of it doing this. Every other time it auto sets is when I'm on a slope and put the truck in park.
Mine seems to auto set the brake every time I park and turn the truck off no matter the incline or lack thereof.
Sometimes it doesn't want to unset the brake when I am ready to roll and I have to push the accelerator hard to get it to let go which scared me the first time it happened - I thought the truck was going to take off and run into something like on the Worlds Worst Drivers show.
Be thankful you didn't have this condition where the parking brake came on whenever the vehicle stopped, like at a traffic light: https://www.f150lightningforum.com/forum/threads/uncommanded-parking-brake-activation.19520/
