Class Action Lawsuit - Home Integration System
Wattsgas
MIke
Brinnon, WA
If you're home (and awake!) the next time there's an outage and automatic transfer doesn't work, try pressing the UNLOCK button on the truck's charger port to the right of the charger head, remove the charger head, wait about 15 secs, and plug it back in again. For me, since October (when I've been awake!), backup power transfer has worked 11 of 11 times, but I've had to use the UNLOCK button trick to get it to work 6 of those 11 times.
My theory now is something about driving the truck, charging it, etc., screws up the truck/FCSP connection state for backup power transfer. What I plan to do in the future is test whether just pressing the UNLOCK button after the truck is charged to its set level and just parked in the garage will prep the truck for a functional automatic backup power transfer BEFORE the grid goes out. But right now, I don't feel like testing the system another 11 times in a row to get good numbers. For the moment, I'm just looking for a Ford update that addresses whatever the truck/FCSP screw-up is...
So I did use your method of pressing the unlock button for the successful power transfer. When I pressed the button the truck seems to wake up, well at least it starts clicking and whirring. So I do believe you are on to something.
The earlier outage had the amber fault light. It did not clear until the power came back on.
I did try it earlier in the month, during as outage and did not have any luck. But in the last month I have noticed that my Ford Charger is reporting my charging statistics more consistently. (I have a spreadsheet with my dailly charging comparing what the truck says vs the charger) Haven't tracked it but think that the charger reports the data when it reboots with the white led bar when it is unplugged. What I have noticed is that I don't always get the white light bar.
I seem to recall there was a earlier forum post about the charger and the truck not reporting the same charge data. With the truck reporting what it accepts and the charger showing what it pushes to the truck. The data is not consistent enough for a thorough analysis. Anywhere from 4% to 15% lost in the transfer.
Thanks for sharing your experience Jim Lewis. It has been helpful.
luebri
Neenah, WI
It was just me testing.
In the Texas Big Freeze on Valentine's Dsy, 2/14/21, even gas pumping stations froze up because they hadn't been adequately weatherized. Home gas generators wouldn't work. I thought the Lightning's battery would be a good protection against other peoples' incompetence. Little did I know ....
Yea I'd be pretty upset if you have manually interact in some manner with your HIS as that is obviously one of the main desired benefits is the auto switchover.
I've got a Dual-Fuel (Propane and Gasoline) 12,000 watt "portable" generator, that to date over 3 years I have managed to only run on Propane (purposely for reduced maintenance). So 2 fuel options, and then the Truck is option #3, with whole panel interlock kit.
Eventually I'll upgrade to a Natural Gas Standby which are pretty affordable in our area, at least in comparison to what I've heard others claim they cost in other areas of the country.
Luckily we seem to have a strong grid here. Yea we get nailed by ice storms but our infrastructure is definitely prepped for that. Tornadoes / strong wind summer storms are normally the other culprit around here. I personally have only been victim to one 24+ hour outage in my 18 years as a homeowner.
Runaway Tractor
Yes
Meanwhile, plugging in ProPower to my generator inlet had my house up and running in 3 minutes. Which seems to be less time than it takes to do an upside down dance while facing west with the left turn signal on at high tide on even days between noon and 3pm in order to get the HIS working, maybe.
The wind bloweth into the new year once again.
Ford F-150 Lightning Class Action Lawsuit - Home Integration System PhotoCollage_20250101_112929221
Same day, same time two years ago before I had the lightning. Cold and loud!
Ford F-150 Lightning Class Action Lawsuit - Home Integration System PXL_20220101_172810950
IWIRE
Nick
2023 F-150 Lightning Lariat
Electrical Consultant
My HIS was delivered on 11/4/24, and I am a Master Electrician, so I installed it myself with the final installation on 12/10/24, and can get the truck to deliver 377 VDC to the inverter, but it stops there, with no conversion to to 240 VAC, and shuts off shortly after. I have made multiple calls to SunRun (totally useless) Delta, (the most helpful), but of limited help and to Ford which told me on 12/31/24 that it is a known problem and they are sending out an OTA update in early January.
it is the reason I bought the Lighting because of the ability to add the HIS, and power my home.
They need to make it work, as the whole system is sizable investment, the truck purchase, installation of the FCSP and the HIS, and then needing to upgrade of the Electrical System to make it work.
Most frustrating is the lack of anyone to get info on the problem, and expected date for the resolution. SunRun installs the system, but say they donā€™t have anyone they can send to service it. Delta just makes the parts, not the installer. Ford ā€˜s name on the equipment, but they donā€™t have anyone they can send for service.
How do you sell a product you donā€™t have anyway to repair or service.
I would be willing to join a lawsuit if they donā€™t get this working soon.
tearitupsports
Russell
Houston, TX
F-150 Lightning Lariat ER
Send me a message. I did a self install and can help you figure out the issue.
Steely
SE Mass
2022 Lightning Lariat
So they're still selling them even though they know they don't work... Interesting.
...can get the truck to deliver 377 VDC to the inverter, but it stops there, with no conversion to to 240 VAC, and shuts off shortly after. I have made multiple calls to SunRun (totally useless) Delta, (the most helpful), but of limited help and to Ford which told me on 12/31/24 that it is a known problem and they are sending out an OTA update in early January.
I second everything you said here.
I'm wondering if everyone's system is in the same failure state or not. If it is then maybe it can be fixed by OTA. If we all have random issues it is hopeless and we need to take some legal action. (This may be needed anyway for long term system support which is a major concern)
I have yet to get any updates since 6.2 whatever the one with karaoke. Never got that ECG-24.2.5.6.3 update in December that a lot of similar 22 lariats got on here. I need to test again but it sounds like you're getting the same error I did where the Ford equipment acts like transfer is in progress but no power is actually sent to the home thru the inverter.
I called Ford again today and got the same known issue waiting for an updated from engineering. They're supposed to have a supervisor call me next week, we'll see if that actually happens.
tearitupsports
Russell
Houston, TX
I don't think all the failures are the same issue.
The main issue is that truck won't communicate to the FCSP and basically won't come on (port light won't turn green). This issue is fixed via OTA somewhere on or around 6.14.
Almost all other issues are quick fix wiring and/or test procedure issues (something that happens after the truck light turns green). Most of these are going to be different from person to person, and can usually be solved pretty easily with a review of components, wiring, etc. The biggest issue with this second set, is that there is no entity that is willing to walk people through these as a system. Each component vendor points fingers at the others without even doing a quick evaluation.
This is why I am trying to help as many people as I can, because I understand the whole system now and can pretty quickly identify the issues.
The hardware in the system is really good, but the system level support is atrocious. Thats why we need to take it upon ourselves to help get everyone working.
Steely
SE Mass
I guess we would have to break things out a bit to narrow down the failure modes.
Systems that are new or never worked like @IWIRE may be helped with troubleshooting from the forum members knowledgeable on the system. If they can get them to a working state we'd have to track all versions and updates they have to be able to compare. Unfortunately, as far as I know, there is no easy way to list all the module versions within the truck to log everything we need for it to be usefully tracked and compared.
The other class would be systems like mine which worked in the past and do not currently. We could track the same version info to compare in an attempt to figure out if there is a hardware failure or software version incompatibility. But again we don't have any easily repeatable way to get this necessary data set for all users affected.
If there was a way to pull the version data it could be useful to have a spreadsheet to track this data and correlate it to what makes a working system. This would be a big lift from multiple members to build and maintain.
Additionally, some documents on how to perform a system test and proper reset so anyone with the system (but less technically inclined) can confirm theirs is working, and do some basic troubleshooting, would be good to have prominently available here in the forums. This would be more welcoming to new users than having to piece it together from various threads. Maybe a How To post could be made and moderated to stay at the top if deemed useful.
Pitbull2o08
San Diego
2011 F150 FX4 Ecoboost
Itā€™s not, at this point about if there will be legal action, itā€™s about who wants to join and how many are having issues and want to join. Iā€™m 100% of litigation simply out of principle at this point. I have 5-6 law firm here in D.C. wanting to jump on this ASAP, but Iā€™m filtering it down to the best viable and capable firm. I appreciate the thoughts of others without the system, but the focus here is for those with the system that do not work or do not work as advertised.
For the comment about the guy that got his truck bought by Ford, Iā€™d love more information and their contact info as thatā€™s interesting to me.
Thanks All!
Filter it down to the amount of money they take home. Otherwise we wonā€™t be close to covering how much we spent on HIS.
Also, Iā€™m in. And my wife is an attorney whoā€™s brain Iā€™ll pick when she comes down this AM
Pitbull2o08
San Diego
The nominal output from the truck is 9.6 kW. That's what shows up as the maximum potential power transfer rate in the Intelligent Backup Power app on the SYNC screen during an actual power transfer. The thing that gets mixed up is that the HIS units are sold with inverters of 4, 6, 8, or 10 kW. But that's the transfer capacity for any attached solar panels. Home backup can be powered by either the truck, solar panels, or wall batteries - but you can't use solar to charge your truck through the HIS unit.
Just a point of clarification, when I had my HIS working I was charging the truck through solar and powering the house. Ford doesnā€™t advertise this but the inverter is capable of it.
Pitbull2o08
San Diego
I am also having issue with mine. I can not get it to work. The best thing it does, is it sends power to the inverter and wont send power to the main panel (house). I just got ECG-24.2.5.6.2.2 updated this week. Do you know if ECG-24.2.5.6.2.2 will update the Bluetooth firmware?
holy shit this is exactly what happens to mine, i thought i was going crazy.
Pitbull2o08
San Diego
Same issue here I think
Is this the known issue that the ota will fix soon? šŸ¤·
i don't know. i know my sunrun tech wanted me to check the voltage in the inverter but I never got around to it due to holiday plans. Now i feel like it's not just me, and this is something else. I always knew that anyway because I've had the system working 2-3 separate times. This must be another software issue.
Jim Lewis
San Antonio, TX
What was implied in my quote but perhaps not clear is that when in off-grid mode, the solar panels can provide power to whatever the "critical loads" panel is but not charge the truck because, IIRC, the truck has flipped from accepting input AC power to providing output DC power from its battery to the inverter. Isn't the critical loads panel then cut off from the main panel and the grid to prevent backflow to the grid (and electrocuting linemen, etc.). So, how will you be able to charge the truck in off-grid mode with solar? Especially since the breaker for the FCSP is usually put in the main panel. Obviously, you can charge the truck with solar output from your PV system in on-grid mode. One person was using his whole main panel as the critical loads panel and had his shutoff point upstream from that. So, if that sort of setup can work and meets code, that might be one way of charging your truck through PV power with truck backup power transfer shutdown. I'm not very knowledgeable about electrical wiring, so my ignorance may be showing.
tearitupsports
Russell
Houston, TX
Jim,
The Delta inverter connection to the truck is bi-directional, just like it is to the home battery system.
With the solar connected to the backup load panel (ac coupled) it will indeed come on and power the loads once it sees a simulated grid provided by the truck/inverter.
At that point if the solar power exceeds the requirements of the load, it will begin back-feeding the truck over DC and start charging it. I have confirmed this, and even posted screen shots from M professional and the truck state of charge before and after in some thread here. I think I got about 3% charge with the truck on about 4 hours (early morning so the solar was only producing about 1.5kW which is 1/4 to 1/3 of its peak).
This is why the HIS system is superior to just a pro power generator hookup, and why I am investing so much time making this system work.
My post is earlier in this thread:
https://www.f150lightningforum.com/...uit-home-integration-system.21562/post-429422
