tearitupsports
- First Name
- Russell
- Jun 1, 2024
- Houston, TX
- 2023 F-150 Lightning Lariat ER
- Occupation
- Industrial Automation & Controls
Have you had further updates such as 10.1.0 and 10.1.1?I received 6.14 update on September 5. On October 4 I had the Frunk reprogram and the Front sensor CSP performed at the dealer. I have one open CSP for the Charge Cable release.
Based on the fact it used to work fine, we will assume there is no wiring issues.
I would guess that it is perhaps a truck modem issue, or a problem with bluetooth.
Does the truck modem seem to be working ok? Does fordpass always update even well out of range of the truck? Is bluetooth turned on still in the truck?
I assume the truck is close to the charger? On mine I usually have the front of the truck at least lined up with the charger. If you are at the full distance of your cord you would be likely too far away. Also you can't have obstacles, such as the frunk up, between the modem and the CSP.
It shouldn't really make a difference, but have you tried testing the system while the truck stays on? I usually test mine with the truck on.
What breakers (besides the charge station) are your turning off to test the system?
