queuewho
Western PA
22 F150 Lightning Lariat SR
Rjpear
Rob
Western PA
Based on the sample notice posted here they gave us a full year to get this done. I don’t see where anyone has a lot to legitimately complain about.
I agree if we have a YEAR then that is fine..but I did attempt to order the part through a Dealer in November and with the help of Ford Customer service they had the part shipped to the Dealer 4 days PRIOR to expiration. Then I Made the appointment BEFORE expiration of the CSP.. but because the work wasn't done (2 days after cancellation of CSP) they denied the work. Kinda Crazy.
BTW.. anyone know how much this thing would cost just to get it done (ball park)?
The Weatherman
Dean
South Central KY
@Rjpear If memory serves, the BMS is a simple swap out. It is small box attached to the battery and can be easily removed and replaced.
That said, it is like a thirty minute service job if done at the service department. So should be more than $150 or so.
I paid about $30 when I did it myself, shipped from Tasca parts to my house.
Rjpear
Rob
Western PA
I see the part is no longer available on Tasca (unless it has been replace by another part number?). I am looking for ML3Z-10C679-B ? Correct?
Yes, but Tasca put a retail sale block on the part after and a few other members bought them, this may still be in place, easiest thing is to go to your dealer parts counter and have them sell you one directly, now that the CSP has expired I see no reason to embargo retail sales, Tasca should release the hold as well.
https://www.tascaparts.com/oem-parts/ford-battery-cable-terminal-end-ml3z10c679b
Ford F-150 Lightning CSP-23B70 Certain 2022-23 F-150 Lightnings - BMS Sensor Replacement 1736685373149-40
https://www.f150lightningforum.com/...tning-csp-23b70-bms-repl-dealerbul-pdf.77576/
Ford F-150 Lightning CSP-23B70 Certain 2022-23 F-150 Lightnings - BMS Sensor Replacement 1736685121843-ws
donalddon
Donald
New Mexico
2022 Lightning Lariat ER Carbonized Gray Metallic
https://ford.oempartsonline.com/oem-parts/ford-battery-cable-terminal-end-ml3z10c679b
mrau
23 Lariat⚡ER
Site says to contact for availability.
Ford F-150 Lightning CSP-23B70 Certain 2022-23 F-150 Lightnings - BMS Sensor Replacement Screenshot 2025-01-12 at 10.09.34 AM
Rjpear
Rob
Western PA
"FUNNY STORY" about this subject CSP.
I attempted in November to get the part (the BSM) chip ordered though my local dealer. For whatever reason after 3 attempts (photo's etc..) they had no luck getting the chip. The Ford Social Media Team who monitor these forums PM'ed me for more info and within a week I had a real live Ford support guy call me. We connected and I explained. They generated a case number, contacted my dealer and on 01/02/25 they had Part in hand. They wanted to get me in on Friday (01/03/25) but could not make that work. So I had them schedule me for 01/07/25 (drop off 01/06/25 at night).
At approx 0900 the dealer calls me and wants to see if I have a case number because for EXPIRED the CSP for the BSM on 01/05/25 (SUNDAY). The back and forth between FORD and The DEALER resulted in NO CHIP FOR ME..after a few months of playing around and not having my Truck for the day. I did get updates done. I wouldn't be so upset if Ford would state that they were wrong about the Chip and it was something else that may cause problems. But all I get is an arbitrary "Expired CSP " 3 days after I made my Appointment.
Ford Social Media Support was awesome as well as their live support. Not sure why this was so complicated in the end.
.. Just as an Update (Final one hopefully!) to this adventure. The Ford Corporate CSM contacted me a few days after my initial issues just to get an update. I explained the expired CSP problem. After a few weeks he called me back and said they found a program to pay for the BSM swap. So today 02/7/25 my 23 Lightning is in the shop for the replacement.
Fingers crossed. I always am concerned with the "If it ain't broke, don't fix it" mantra..and even if it wasn't working before..i didn't notice.
ScubaSteve_TheReal
Steve
Midwest USA
Derivatives
I only bought my truck March 20, 2024…
That’s just great. I missed getting mine replaced. Who knew it expired..?? Will see what I can do to get the part# ML3Z-10C679-B
digitaldad
ABQ
2023 Lariat ER MaxTow
Remember to do a BMS reset after replacing it then.
This is BdyCM reset, correct? This "abbreviation" doesnt seem to stick with me and my infrequent use. I'm always looking for BMS, specifically.
I ordered this part when I also ordered the security pack removal motion sensor. I attempted DM'ing Ford Corp and through my own dealer (and calling the customer satisfaction toll free number) to see if I could get it comp'd...since my truck was sitting on a lot/process of being sold by original owner, I assume they snoozed taking it in...when the CSP expired, I was trying to get it covered gratis, but alas, DIY for me.
@bmwhitetx, I saw earlier in this thread, you were asking for one of the pulled/affected units, I have to think you have since gotten your hand on one (or your own), but if you want mine, it is yours.
Let me know.
EDIT: Duh, me.
Let me know.
DM sent on your offer!
BMS stands for Battery Management System. This is not the same as the Body Control Module which is abbreviated BCM (or in FORScan BdyCM).
Typically you only reset the BMS when you change the battery as it keeps track of battery age. The service procedure for the replacement doesn't mentioned resetting the BMS, and my tech didn't, so you may be okay.
But if you really want to, the procedure is here:
https://www.f150lightningforum.com/...em-bms-learned-values-reset.15900/post-323350
mr.Magoo
2022 Lariat ER, AMB
I belive the campaign ended, so you'd be paying to have it replaced.
If you're even the slightest bit mechanically inclined you can replace it yourself in 5-10min.
There's links in the thread to where you can buy a bew one.
