Turn Signal Indicator blinking fast
gbuydos
Central Iowa
F150 Lightening Flash '24
My turn signal indictors on the dash just started blinking fast when activated. All the actual turn signal lights are working. What could possibly cause this.
I have had an issue with blind spot assist and rear parking sensors. Are they all tied together?
Whammy Bar
Take your "Lightening" to the dealer and let them deal with it. Perks of a new car with a warranty.
Old Aviator
Larry
WPB, FL
22 Lightning Platinum 06 Magnum SRT8 23 Ocean One
Consultant
If your Ford Lightning's turn signal is blinking fast, it usually indicates a burnt-out turn signal bulb on that side of the vehicle; the faulty bulb disrupts the electrical circuit, causing the rapid blinking as a warning that a bulb needs to be replaced
gbuydos
gbuydos
Central Iowa
I agree, but taking the car to the dealership is a pain in the ass. Sometimes, with the help of these forums, this is a known issue and the answer may be a lot simpler that a torture session at the dealership. Just trying the simpler path first.
Its odd that both right and left would go south at the same time. I replaced a tail light over a year ago with a used one from eBay and it hyper-flashed. The other one still acted normally. Seller refunded my money. Got another used one and it worked.
I agree - dealer issue at this point. You can disable it in FORScan but wouldn't recommend it.
The blind spot sensor is in the tail light.
JerseyMike
Allentown, NJ
2022 Ford Lightning Lariat SR, 2" pucks, P275/65/20 Nitto Recon
I had the same and noticed that one tail light was out and had some condensation in it. dealer replaced it and it fixed the issue
Adventureboy
I've had this with a burnt out bulb on a trailer. All lights on the truck were fine and it returned to normal when trailer was disconnected. Any chance you've connected something to the trailer electrical port?
sysop1
St.George
Gas
My left blinker double flashes when the temp is above 60 and the front light blinks white, not orange. It works OK when it’s cold out. Dealership has no idea, seems I have to live with it.
Duke_239
Duke
2023 F-150 Lightning
Hilarious. Does the AI know these are all LEDs?
