Powertrain Malfunction/Reduced Power Poll
Have you had the Powertrain Malfunction/Reduced Power issue
  • Total voters
    308
Aaaaaand mine is back at the dealer. Reduced power as well as threw a powertrain faulut (wrench icon).
Back in a nice new 2024 F150 STX rental with 11 miles. Ironically bluecruise works just as good in this thing as the one in my Lightning.
Dealer said it'd be a week to get an update.
Sigh.
Did you pull the DTC before you dropped it off?
Avocadodude
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
Sigh.
Sorry to see you in the repeat visitors club. How long between repairs for you?
Whammy Bar
February 24.
I had to bring it back in March because it ran out of coolant when they probably didn't bleed it correctly after a module replacement. Pulling out of the dealership, it lost half power again and threw a bunch of issues. I couldn't leave it because I didn't have the physical key. A couple key cycles later and it cleared it's faults. I've been driving it since until it once again did it on Saturday. So back in it went...
UFLightning
Kevin
Jupiter, FL
2023 F-150 Lightning Lariat
Updated my vote as I joined the club yesterday :sadface:. I was charging at work, made it to my preset charge limit then I hit "Charge to 100%" in anticipation of a trip I'm taking today a few minutes later I received a charge fault and power train malfunction errors. Now I'm at 57% power available and the truck will no longer charge (level 2 is all I've tried). At least it didn't happen when I was out of town.
The purchasing dealer offered me an appointment on June 29th :cwl: with no loaner. Another dealer a bit further away can get me in next week and should have a loaner available, but I opened a case with the Ford BEV team just in case.
I'm at 13800 miles...
Update on my repair, the second dealer I contacted was able to get me in on 5/15 and provided me with a loaner gas F150. According to the final paperwork battery module #6 was bad, they ordered the replacement module, heat shield and thermal paste. The repair was completed on 6/6 , 22 days total in the shop (it seems that they had an issue with cell balancing that took an extra couple of days).
Everything seems to be back to normal, I appreciate the dealer getting me an appointment in a reasonable time and the loaner was definitely key for a repair of this length. The only gripe was the lack of communication during the process.
This has been an interesting experience to me as someone who is mechanically inclined, for the first time in my years of owning and working on cars I realized I don't understand what "broke", it's a weird feeling... It will be more difficult for me to get my confidence back for road trips.
Whammy Bar
Got the truck back after another 21 days in the dealer. It sat untouched for a while, then they completed the recalls for the BMS and "feature" where it wouldn't revert to Normal mode. TO address the powertrain fault, they dropped the battery and replaced the SOBDMA. The previous trip in they dropped the battery and replaced cell 6 (I think).
Fingers crossed this is the fix.
Also, fun fact. My gas F150 loaner was able to supercharge at Chevron to a range of 672 miles. It only actually goes 501 miles (with 10 miles DTE)... so they can't get it right in the vehicles they've been building for 100 years either.
Temix
F150 Lighting Lariat
My truck spent two months waiting for parts with the same issue. Funny enough, after getting Ford executives involved, the problem was resolved in a couple of days. They claim it was just a coincidence and had nothing to do with speeding up the process, but I find that a bit suspicious. :sunglasses:
BuzzLightning2023
Los Angeles
92 Explorer,94 F150,06 Avalanche,05 F250,11 F150
Question for the “Yes now resolved” group: how many days was your truck out of commission? Thank you.
Temix
~65 days.
In my case, this was one of the first Lightnings in Ontario, and the dealership had no idea what to do with it. I believe the current situation with dealership training and parts availability should be much better.
BuzzLightning2023
Los Angeles
Update on mine: DAY 16: a lot of movement yesterday and the service manager wanted to take it home for an extended test drive after “replacing a wiring harness”. Charging it at 5 Kw at dealership now. They want to run more tests before giving it back to me today. They’re running out of hours and I told them I want all DTC’s, SSM’s, TSB’s, etc., cleared and all updates performed. Crickets since then…
BuzzLightning2023
Los Angeles
Update update: 45 minutes before they close, dealership calls and my truck is fixed. Bucket of codes cleared. Wire Asy Jumper part NL3Z14A411D replaced, 12v battery connections checked. Truck seems fine.
changing my vote to resolved.
Broonarmy
F150 Lightning, 2022 Lariat ER, Smoked Quartz
I've just joined the repeat occurrence crew :-((
I would love any info on how likely I can get a repurchase through?
Piquette
Trent
New Hampshire
2022 Lightning Lariat
When my second battery module failed at the first of the year and 22k miles I contacted Ford and requested a buy back. After a month they called me to ask if I had the truck back, which I did. They don’t seem to be very responsive if your truck isn’t at the dealership waiting for parts/repairs.
Keep us posted on how you make out.
