skaphan
- First Name
- Shel
- Aug 5, 2021
- Seattle, WA, US
- Subaru Outback
Trying it is the best way to find out. Some people use a UPS for "grid forming" for their solar inverters like this. But if you do this you should make sure your household circuits are separated from the grid, via a transfer switch or mechanical interlock between breakers for the generator (or other AC source like an inverter on a vehicle) and the main breakers so both cannot be on at the same time. A grid-tied solar inverter synchronizes with the grid and shuts off if the grid goes down. Other AC sources are probably not smart enough to do either.Fully agreed that a regular inverter will run most anything. Power tools, TV, I’ve done those. And I’m sure Ford will provide the same quality AC electricity. But will it be good enough to trick the PV micro inverters into producing? I’m sure someone will try this with a spare panel and micro and will let us know. Looking forward to seeing it!
