“Hands on steering wheel” sensor not recognizing my hands
Peter_F
Petrr
Wisconsin
Mach-R & Lightning, Lariat, ER, Antimatter Blue
Hi all.
Very happy with my Lighting only one thing is a nuisance… the sensor in the steering wheel is not “recognizing my hands” while driving.
this results in a more or less constant “hold the steering wheel”-reminder… when it shows up I have to slide my hand on the right lower side of the steering wheel to get it to go away.
am I the only one or is this an known problem…
I’ve driven 10,000 miles and it’s getting to be a little annoying.
Peter_F
Peter_F
Petrr
Wisconsin
As in pressure?
As in pressure?
Yes. It has to register torque from turning the wheel, even if it's very light, within a time limit if you're not in hands free mode.
Peter_F
Peter_F
Petrr
Wisconsin
So “wiggling” the wheel while in lane-centering mode would help? Still a hassle though.
Never had any issues like this in the Mach-E…
My Mach-E seems more sensitive to this than my Lightning. Maybe it’s just vehicle to vehicle variation.
xycarp
SE Michigan
2021 Bronco Sasquatch, Lighting Lariat ER on order
I rest my elbow on the window sill, and hang my index finger over one of the spokes on the side of steering wheel. The truck senses the weight from my arm, but it still steers on its own. It works pretty well.
TheBigBezo
Earth
F-150 Lightning Lariat ER
I usually hold the wheel with one hand and more or less softly oppose the steering to keep force on the wheel. If it's leaning left to follow a curve I'll just a finger or two to push the opposite way.
You don't need to wiggle it. A slight constant pressure one way will work.
luebri
Neenah, WI
I typically go with a wiggle and a passive aggressive eye roll!
Peter_F
Peter_F
Petrr
Wisconsin
None of these options works for me. Even if I hold both hands on the wheel, it still freaks out 🤦🏼‍♂️
SmoothJ
New Jersey
2021 F150 HEV
As others have stated it’s torque based, not touch. If the truck is driving straight, add some pressure to either side of the wheel either in anti-clockwise or clockwise manner.
ctaschuk
Regina, SK Canada
2023 F-150 Lightning
The torque-based tricks work. However, they shouldn’t be necessary - I can drive in my other brand car all day without having to think about these little torque inputs. Hopefully Ford adjusts the sensitivity with a software update soon.
VAF84
Central Texas
2024 Sierra EV Denali
Consultant
I had the same issue, it was beyond annoying. My solution below solved it for the most part. The 1 lb weight from Amazon did the trick. Won't help you in the city as it gets in the way, but it does on long stretches of highway.
Ford F-150 Lightning “Hands on steering wheel” sensor not recognizing my hands IMG_1212
WhipSticks
Stephen
Maine
2023 F150 Lightning
Scientist
I use my knees...
