i am still not getting the c/cm on my forscan🤦‍♂️
Maybe you miswired it. Did you look at the link I sent in post 572 and then the ones after it.
dr1983
dennis
2022 Ford Lightning XLT
Security Advisor
i have the original wiring and the passenger and driver have both wires
B177y
Olympic Peninsula WA
www.ptcoffee.com
2024 Lightning Pro ER Max Tow
Coffee Roasting
Go back to step 1 on the first post and trace your steps all the way through.
I reversed my wiring on the CCM plug, check that. When I fixed it, I was able to then program it successfully. Check ALL of your wiring.
I also didn't understand how to use the ForScan master spreadsheet that is referenced in post 1 on my first attempt. I watched a YouTube video that is posted somewhere in the 20's pages of this thread and learned how to use my stock ForScan values and what I needed to change them to. They were different than the OP's. Understand that step before you start changing ForScan values again.
Don't use the "easy mode" for this mod, it likely won't work.
That is really all of the help that I can suggest.
dr1983
dennis
Security Advisor
roger thanks
