Environmental controls frozen
Mach_5
Burnaby, BC
2024 F150 Lightning
Carpentry
Had this problem for a few days a while back and it went away, but it's back.
When I turn the truck on the environmental controls (cabin temp, heated seats, defrost, AC, etc) are all dead. The recirculate air button is lit up, the A/C button flashes, and the fans are blowing cold air at maximum. I can turn the truck off and on a few times (sometimes it takes 6 or 8 reboots) and it goes away. But if I park at a store for a few minutes and come back to turn it on I have to go through it all again.
Anyone have an idea on a possible fix or should I just take it in to the dealer and get it checked out? Still under warranty just trying to avoid the hassle ?
What was your most recent OTA update?
Have you tried a 12v negative battery terminal disconnect ?
Mach_5
Mach_5
Burnaby, BC
2024 F150 Lightning
Carpentry
I'll look up and try the 12v negative battery disconnect, thank you!
Latest update is ecg-24.2.5.7
Mach_5
Mach_5
Burnaby, BC
2024 F150 Lightning
Carpentry
So I didn't get around to trying the 12v battery trick.... But I did happen to just let it blow the cold air while I was driving and it eventually stopped after maybe 5 mins on it's own and hasn't happened again the last few times I started the truck. Weird!
B177y
Bill
Oly Pen, WA
2024 Pro SSV ER Max Tow
Sounds like a climate control module (or modules) didn't boot up on vehicle start and booted or reset during your 5 minute drive. I would disconnect the 12 volt battery negative terminal for 10 minutes. When you reconnect it, make sure both terminals are tight. That will sometimes help to reboot sticky modules.
Henry Ford
Try a Sync reset and check the coolant level. To do a Sync reset hold volume down and skip ahead on the steering wheel until the Sync screen resets. Sync resets solve a lot of weird glitches.
If the coolant is low you'll have heating issues.
