F150 Lightning FORscan thread
Status
Not open for further replies.
BennyTheBeaver
2023 Lightning XLT ER
Anybody know if there is a forscan setting that turns on the emergency brake (hand brake) automatically every time the car is put in park?
Even with a 2 degree slope on my driveway, the auto emergency brake does no engage. The only remedy is to open the door before I put the car into park as that is the only way I know how to manually engage the emergency brake but this seems silly.
Is there something wrong with your Parking Brake button near the Headlight control. It's a Push/Pull button/level. One way engages, the other disengages.
This is coming in a SW release. I believe it may already be on the Mach E. It has been noted however. Tesla has done this since day 1 and Ford is adopting the strategy.
Otherwise it is push/pull to engage and disengage. I don't remember which way is which.
Having an issue with Global Windows. Did every change, even went in to the module and confirmed that now it says Enabled for each one, yet doesn't work. Lariat, April 2022 build.
Blochead21
PA
Black 22 XLT 311pkg
Did you enable it on the trucks screen settings?
I did not. Didn't see that in the info. Will check this morning.
Edit - that was it. Never dawned on me that someone would want to not have that feature turned on, and there would be switches for it. Much obliged.
WildBlue
Somewhere
2024 F150 Lightning Flash
Hello! Quick question about the front light bar adjustment (making it brighter) using Forscan. Does the mod also adjust the brightness of the left and right side components of the light bar (those 7-shaped DRLs on each side)? Or only the main bar attached to the hood? Hopefully the entire bar and sides are brightened with that setting change. Thanks!
There is only one video where the owner believes his light bar is brighter. I don't think there is much more confirmation or belief that this adjustment is really working. It works for the DRL's on an ICE truck, so it was attempted, but not sure you'll really get anything out of it.
Flash
Don
Htx
2023 F-150 Lightning XLT 312A
EE
Nothing wrong with the lever but a auto parking brake feature is something I have on every other vehicle so I was hoping my 60K truck would be able to do it also.
BennyTheBeaver
Hmmm. I personally would hate the truck applying the parking brake everytime I parked, especially on a flat surface. My driveway is on a 6 degree incline so it does auto apply for me when I park at home. To each their own though.
Flash
Don
Htx
EE
My driveway has a 2 degree incline and it never auto applies the parking brake. It makes a very annoying lurch backwards if you don't apply the parking brake manually. I personally would like to have the parking brake applied every time the truck is parked because why not?
First Time Ford
Joe
Smithers BC Canada
2022 Ford Lightning Lariat ER
Self Employed
Interesting. Maybe I’ll try another then.
Did you try a new sensor? Did it fix the problem? Also do you know the voltage at the plug which wire? I assume the truck needs to be on and wiper stalk on as well?
First Time Ford
Joe
Smithers BC Canada
Self Employed
Thanks,
Mmiketa
Virginia, USA
'23 Lightning Lariat ER
I use single pedal driving, but when I stop I get a notification on my dash indicating “parking brake has been applied”.
dingmah
Edmonton, Alberta
2023 Lightning Lariat SR
Hi everyone,
I want to disable the door ajar chime. But when I look at the IPC spreadsheet, I'm confused what value I should be replacing in the place of the *.
Disables door ajar chimeIPC720-01-02xx*xxx--see IPC spreadsheet to disable EIOCM
Any help is appreciated. Thanks!
acseaman
Andy
2023 Lightning
Has anyone successfully performed the mod for folding mirrors?
Lincoln Folding Mirrors Setting (folds when locked--only unfolds when ignition started): successful in Lariat ER with 5/5/22 build date.
DDM740-03-16xxxxxxxx01--
PDM741-03-16xxxxxxxx01--
My understanding is the mirrors should remain folded when the truck is unlocked and the doors is opened. They should unfold when the truck is started or the door is closed (which ever happens first). and should remain folded if, after the door is unlocked, opened, locked and then closed again.
What I am seeing is the mirror is stay folded when the door is unlocked and opened. If I hit the lock button, the mirror immediately unfolds and remains unfolded when the door is closed.
If I unlock, open the door and manually press the lock rod down, close the door, the mirror will unfold and immediately fold again.
Status
