F150 Lightning FORscan thread
Status
Not open for further replies.
Mike G
N. AL, USA
Understood. What's odd is that enabling Glare Free, but not toggling it on, disables Auto High Beam. This would suggest the vehicles with Glare Free from the factory also don't have Auto High Beam, but then why would there be an Auto High Beam setting on the dial? Maybe those trucks have a different dial that does not have the setting?
At least it seems odd to me.
What seems odd to me is that from the system description (attached), you would think that all higher trim trucks have the glare free function built in already. And that all you had to do was turn it on or off from the settings screen.
Howard_Scott_Warshaw
2022 Lariat ER, rapid red
Wow, that's very neat. Nice find. It's my understanding that at the time of production, the Glare Free feature was not yet approved for use by the DOT, NHTSA, or whatever else organization is in charge. Ford included the capability (perhaps to cut down on variants and SKUs) but did not enable it.
Nice find! It may be an oversight but the glare-free system only appears under the section Headlamps -LED Headlamps -Except Electric Vehicles. Not only is there Glare-Free but Automatic Headlamps Leveling which also sounds cool.
The next section, Headlamps -LED Headlamps -Electric Vehicles Only has neither Glare-Free or Automatic Leveling mentioned.
LUXMAN
F150 Lightning PRO and XLT
Pilot
Does anyone know how to make SPORT mode the Default or make the truck stay in the last mode?
I know there was a software update that "fixed" an issue with the truck staying in OFF ROAD.
I was hoping to figure out how to make SPORT the default.
Figured I could get @GDN to program that and a couple other things for me in exchange for some ??
Who said ?? I'm easily pleased.
I've slept since then, but when we did your bed lights did we activate Glare Free for the headlights?
LUXMAN
Pilot
They stayed working after the forced updates. It was just the bed lights that returned to the default.
I want to get at least the seat belt reminder turned off and the cameras enabled for full time use. And the SPORT mode but not sure how.
We need someone to weigh in on the cameras for full time use and exactly what they changed. That is the change I made that removed my one pedal switch from the screen.
LUXMAN
Pilot
I have an ask out on that. And I will ask if that has happened to him, if he replies.
What again did you do to get it back?
I found the setting in the not "as built" section for one pedal drive. Turned that on. and looked to see what it changed in the As Built. Found it was one of the setting changes I had made for always on cameras.
sharper4
DFW
Does anyone know the code to use to change the number of blinks to 4 in the SCCM module? I can only find codes for 3, 5 and 6.
Change Number of Blinks in Turn Indicator (From @jredondox)
724-01-01 XXXX-8CXX XX for 3 clicks
724-01-01 XXXX-94XX XX for 5 clicks
724-01-01 XXXX-98XX XX for 6 clicks
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
I don’t know for sure but converting hex to decimal:
8C=140
94=148
98=152
Each click is an increment of 4 so you probably need 144 decimal which is 90 hex.
8C=140 decimal 3 clicks
94=148 decimal 5 clicks
98=152 decimal 6 clicks
Interpolating
90=144 decimal 4 clicks
So 90?
I changed mine to 5 and sometimes only get 4. So YMMV.
Give us an update if you do use the new of 90.
Mmiketa
Virginia, USA
'23 Lightning Lariat ER
I used the interface instead of the code and just selected 4 blinks from the drop down.
Reactions: GDN
Status
