408sbfmustang
- First Name
- Mark
- Jun 9, 2021
- San Jose, CA
- 2021 Ford F150 XLT 3.5 Sport
- Occupation
- Tech
Hello, looking for the Ford publication that states what the front brake caliper brackets to knuckle should be torqued to and if the bolts are one time use.
I’m asking due to my truck had the ball joint recall two weeks ago and they ended up replacing both steering knuckles . Well after the brake assist/ABS kicked on yesterday the left front caliper came loose and was making a noise when I would hit a bump or reflector.
They are claiming they didn’t torque them correctly but I tried to see if I could tighten them before I call them and I couldn’t tighten or loosen the bolt. I was able to spin the washer.
